<dei-feif> wrote in messageI
href="news:6086597@discussion.autodesk.com">news:6086597@discussion.autodesk.com...
keep mine off. When I turn it on, I seem to run into that annoying "A command
is in progress" error (although I haven't tried it now since pre-SP 2009 - is
this still a problem?). Although, after keeping Autosave turned off ever since
I first started using C3D 2007, I'm kind of used to it by now. -- Sinc
http://www.ejsurveying.com http://www.quuxsoft.com
(Sincpac-C3D)
I get the same problem with 2010 and 2011, i think if it crashes during an autosave then it gets disabled, it appears to be a recurring problem that autocad autosaves regardless of processing load at the time, resulting in crashes.
I Don't know what might be turning it off. But a workaround would be to set in on in a startup lisp.
BTW I'm on the same release as you and don't have that problem.
Allen
Allen Jessup
CAD Manager - Designer
I create a separate folder and point Autosave to save there. I have the folder set to Read-Only. So even when Civil 3D closes normally the backup files aren't deleted. You just have to remember to clean out what you don't want every once in a while. I'll leave one for each day as a record and burn them off to a DVD every couple of months.
Allen
Allen Jessup
I do like Allen does and create a temp folder that I roam through and cleanout periodically....
Been doing this for years, many prior to Civil 3d and have used this from Civil 3d 2008 on up.
In my acaddoc.lsp file I have the following line
(command "SAVETIME" 10)
this sets (or resets) the autosave variable at the start of every drawing. Autosave may cause slow downs and even fatal errors during complex processes, but I have rarely lost more than 5 minutes of work and sometimes the crash actually helped by forcing me to rethink the process I was attempting.
Just another option or thought process
Good luck,
MB
The "SAVETIME" works well, I also include a batch file in the save folder with the following;
ren *.sv$ *.dwg
ren *.bak *.dwg
Makes the drawings easier to sort and open
