• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    dano11372
    Automated linework
    380 Views, 19 Replies
    12-13-2011 12:04 PM
    We are now working in civil 3D 2011, and have started using the .txt files now instead of the fieldbooks of the past. I have created a Description key set, along with a figure prefix database and a linework code set. everything works fine as long as the field crews use EP1, EP,2 EP3, ETC.. But we would really like to utilize the Begin and End function of this. I have unchecked the box that says Automatic begin on figure prefix match, but still no luck. I have also checked the linework code set and it all looks good <Space> delimiter etc.., any help would be greatly appreciated thanks.
    Please use plain text.
    *Expert Elite*
    Re: Automated linework
    12-13-2011 10:39 PM in reply to: dano11372
    EP1 B will work nicely to start a new figure unless you've edited the linework code set.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Active Member
    dano11372
    12-14-2011 05:55 AM in reply to: mathewk
    yeah, i have tried using the B EP or E EP, but When i import the .txt file in it does not draw the linework. like i said if i have the box checked automatic begin on figure prefix match and use EP1, EP2 ETC.. it works fine. but we do not want to change the description everytime we need to break a line.
    *Expert Elite*
    12-14-2011 07:36 AM in reply to: dano11372
    If you have that toggle unchecked you MUST use the begin and end codes. If it's checked then you don't. That's just the way it works. You don't need to use a different description to break a line just the E and B codes.
    Matt Kolberg
    12-14-2011 10:09 AM in reply to: dano11372
    Not sure if it is just a typo in your post, but the linework codes need to be entered after the point codes:  EP B and EP E.
    David Zavislan, P.E. | CAD Manager / Associate | NV5 | www.nv5.com
    *Expert Elite*
    12-14-2011 12:13 PM in reply to: david.zavislan
    I believe this can actually work both ways.
    Matt Kolberg
    Active Member
    dano11372
    12-14-2011 02:16 PM in reply to: david.zavislan
    I have edited the .txt files to try both ways, still no luck.
    Active Member
    dano11372
    12-14-2011 02:17 PM in reply to: mathewk
    Yup, tried both ways editing the .txt file to reflect the EP B or B EP, no luck
    Active Member
    dano11372
    12-14-2011 02:25 PM in reply to: dano11372
    Could it be a problem in My Description keys Format, i have all format set to $*. and most of my codes are EP*, FNC* etc..
    *Expert Elite*
    12-14-2011 02:28 PM in reply to: dano11372
    Desc keys have no bearing on what happens with survey figures.
    Matt Kolberg
