Autocad Civil 3d 2013 & Windows 8
Message 1 of 90
I would like to post the probleme autocad civil 3d and windows, i try to install it but during the installation wizard "framework 4" the process stopped and the installation wizard crash
can anyone post a solution for this problem
Replies (89)
Message 81 of 90
troma
Earlier on this thread, or possibly on one of the other similar ones, a user shared this suggestion: the problem originates with the updated .NET framework that comes with Win8.  The suggestion is to remove the .NET from the machine, and install an older version of .NET. The user then reported no problems in operation.
Mark Green
Working on Civil 3D in Canada
Message 82 of 90
Tried that - did not work.
kudos if it works.
Message 83 of 90
neilyj666
C3D 2014 IS supported under Win 8 http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15444804&linkID=9240697&CMP=OTC-RSS... but Win 7 is recommended
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 84 of 90
Jeff_M
Note that it says Windows 8 Professional. So most new pc's that "come with Windows 8" still need to be spec'ed to upgrade to the Pro version.
Jeff_M, also a frequent Swamper
Message 85 of 90
neilyj666
Maybe not sure of the differences but I have Win 7 Home on my laptop and Pro on my desktop and Civil 3D 2013 runs fine on both.
Perhaps it's so you can run compatibilty mode for Win 7..!?!?!?Smiley Wink
Message 86 of 90
michael_robertson
Regular Windows 8 should probably work fine, the main difference between regular and pro editions are enterprise type capabilities such as:
Remote desktop connections
the ability to participate in a Windows Domain
Encrypting File System
Hyper-V (virtualization)
Virtual Hard Disk (VHD) booting
Group policy
Bitlocker & Bitlocker-to-go
For full version comparison see Wikipedia: http://en.wikipedia.org/wiki/Windows_8_editions
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Message 87 of 90
Hot Fix 3 appears to have resolved the Windows 8 issues.
I have been running since yesterday.
Anyone else seeing positive results?
Message 88 of 90
downloaded and tried it -
anything in 2d works (did before) but still crashes when editing Civil 3d modules.
could be because everything here is networked to a server.
Message 89 of 90
I was able to work with sections that caused it to crash before.
Yeah!!!!
Message 90 of 90
Yes! I'm up and running now with no major crashes. I say 'major' because, now, I receive an error regarding the .Net framework but it doesn't crash. C3D just errors and allows me to continue. I haven't tried all functions yet, so it's early... I was crashing roughly 10 seconds into working in any drawing.
