• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    bo.martin
    Re: Autocad Civil 3d 2013 & Windows 8
    12-11-2012 03:30 AM in reply to: jjenkins1115
    After I installed Service Pack 1 my crashing issues went away.
    I also installed Start8 to bring a start menu back.
    I really prefer 8 to 7 now.
    Please use plain text.
    Active Contributor
    12-11-2012 10:55 AM in reply to: bo.martin
    I'm running C3D 2013 SP1 on Win 8 with no major issues (so far). My computer is a 5+ year-old Core 2 Duo 6400 with 2GB of RAM, and Windows 8 (32 bit) and Civil 3D both run great. I upgraded from XP, so going to Win 7 is not really an option. I've been running Win 8 since September, and upgraded to the final version the day it was released. Windows 8 boots up and runs significantly faster than XP ever did on this machine. No way would I go back to XP. BTW, I second the recommendation for Start 8. Best five bucks I've spent in a long time. :smileyhappy:
    New Member
    01-30-2013 10:06 AM in reply to: fayoud
    Widows 8 x64 + Civil 3D 2012 = no work.
    As long as I am using it as AutoCAD, it works fine.
    As soon as I start thinking about creating an alignment, crash. Haven't tried anything else.
    Then I discovered this topic, so at least I am not thinking about smashing my compiter anymore:smileylol:
    Btw, my system is:
    AMD A10-4600M with Radeon HD Graphics @ 2.30 GHz
    8 GB of RAM
    x64 Windows 8
    Very dissapointed.
    I saw one guy mentioning C 3D 2013 working good on Win 8.
    Anybody else with positive experience on that?
    *Expert Elite*
    DarrenP
    01-30-2013 10:11 AM in reply to: ingotiblum
    autodesk never said civil 3d was compatible with windows 8
    Valued Mentor
    01-30-2013 10:14 AM in reply to: ingotiblum
    As this thread has pretty much pointed out:
    C3D 2012 & Win8 = not stable & no support
    C3D 2013 w/o SP1 & Win8 = iffy & no support (some seem to not be having a problem)
    C3D 2013 w/ SP1 & Win8 = works & no support
    Mike Robertson
    FL. Dept. of Transportation
    CADD Applications Developer
    HPxw4600 Workstation
    Core 2 Duo 2.33ghz, 8gb RAM
    nVidia Quadro FX1700
    Win7 64bit
    Valued Contributor
    bo.martin
    01-30-2013 10:43 AM in reply to: bo.martin
    I've found that the most issues I have with windows 8 and C3D 2013 is working with profiles & pipe networks.
    Luckily if I'm going to be worikng on profiles I reboot to a different HD with win 7 loaded.
    Member
    03-04-2013 02:20 AM in reply to: ingotiblum
    I've got the same pbromlems. Autodesk Civil 3D 2013 (on Windows 8) is working normally like Autocad. But doesn't work at all with Alignmen, Surfaces etc...
    And I think there is only one solution for this problem - uninstalling  Windows 8.
    Sad but...
    *Expert Elite*
    neilyj
    03-04-2013 02:42 AM in reply to: AQUARI
    This topic has been discussed ad nauseum - but to reiterate: at this time no version of Civil 3D IS SUPPORTED UNDER WINDOWS 8
    Can we please draw a line under this topic now......:smileyfrustrated:
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    New Member
    03-07-2013 11:27 AM in reply to: bo.martin
    I got it, Windows 8 isn't supported nowadays, but my question is... does anybody know when it's going to be supported? I need this program to an University's subject... so I need it quickly.
    But I can't understand why it works in some computers and doesn't works in others. What does it depends?
    Valued Contributor
    bo.martin
    03-07-2013 11:47 AM in reply to: xsara0905
    I have no problems on Windows 8 with the majority of what I do.
    Profiles, Pipe Networks, Sections are where my problems occur.
    I just reboot to a secondary HD with win 7 installed any time I
    have to do the above.
    HTH
    Robert
    Edit: Profiles work ok. Just did some last night
