• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    fayoud
    Re: Autocad Civil 3d 2013 & Windows 8
    10-09-2012 08:36 AM in reply to: michael.robertson
    Bonjour, mais cette méthode ça marche pas
    merci
    Oudjhih Fayçal
    Please use plain text.
    Active Member
    10-29-2012 11:22 AM in reply to: fayoud
    Any one having issues with the final release of Windows 8 and Autocad Civil 3d 2013?
    Everything works well, couple of minutes having the program running, the program crashes.
    Tried different drawings, no luck.
    Installed "Hotfix 2" no luck
    Running with 64bit and as the administrator.
    *Expert Elite*
    neilyj
    10-29-2012 11:33 AM in reply to: fayoud
    it's still an unsupported OS so problems will be inevitable
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Valued Contributor
    bo.martin
    10-29-2012 12:25 PM in reply to: kra1366
    Being running 2013 on Win 8 Final Release (RTM) for over a month.
    I did have a crashing problem and it ended up being the drawing.
    Other than that no issues.
    Have you updated your video drivers from your MFG web site?
    All updates to win 8 installed?
    Here is my system
    Gigabyte MB, i5 3570 CPU, 8 Gb Ram
    Corsair SSD Boot, 1TB WD Data Drive
    AMD 6850 GPU (Not certified) (I play games)
    Dual 24" Monitors
    At work we have AMD V3900's for the GPU
    Great $120 video card. Solved quite a few issues with 2013.
    Haven't tried it on 8 yet.
    Good Luck
    Active Member
    10-29-2012 01:01 PM in reply to: bo.martin
    Thanks for your responce.
    Updated the vidieo card drivers
    I installed all the current Windows updates.
    Installed the Autocad hotfix 2 .
    I just re-installed Autocad. No luck
    I tried another drawings, does not seem to make a differance.
    Sony laptop, Core I7 Processor
    8gb ram
    256 gb Sandisk Extreme SSD
    Suggestions?
    Back to Windows 7?
    Valued Contributor
    bo.martin
    11-01-2012 03:58 PM in reply to: kra1366
    Well it seems that windows 8 doesn't like cross sections.
    It crashes when I try to work with sections. On my win 7 system
    same dwg works fine.
    Argh!! I'm really liking win 8 too.
    Bo
    *Expert Elite*
    neilyj
    11-02-2012 01:16 AM in reply to: fayoud
    AutoCAD + Civil 3d + Windows 8 = User Beware
    neilyj
    New Member
    11-04-2012 06:16 AM in reply to: fayoud
    i have Autocad Civil 3D Land Desktop Comapnion 2009
    and i would like to install windows 8
    if i install it, will the application stay working after the switch or will i need to reinstall autocad?
    *Expert Elite*
    neilyj
    11-04-2012 08:16 AM in reply to: anthonyad
    Refer to previous posts - Windows 8 remains unsupported and Autodesk software may or may not work - I'd suggest it may not be worth the hassle in a production environment at this time
    neilyj
    Valued Contributor
    bo.martin
    11-04-2012 04:52 PM in reply to: anthonyad
    Buy a new hard drive, do a clean install to it.
    I'm going to buy anothe SSD so I can boot into
    win 7 if I have to do crosections.
    If it's your only hardirive I'd say no to windows 8 if
    you need to use autocad.
    Bo
