• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    fayoud
    Accepted Solution
    Autocad Civil 3d 2013 & Windows 8
    8462 Views, 89 Replies
    09-19-2012 12:58 AM
    I would like to post the probleme autocad civil 3d and windows, i try to install it but during the installation wizard "framework 4" the process stopped and the installation wizard crash
    can anyone post a solution for this problem
    Oudjhih Fayçal
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Autocad Civil 3d 2013 & Windows 8
    09-19-2012 02:03 AM in reply to: fayoud
    Windows.. what?? How did you get that?
    Don't be surprised if something's going wrong on a beta OS, sir...
    *Expert Elite*
    neilyj
    09-19-2012 03:08 AM in reply to: fayoud
    Windows 8 is not supported by any Autodesk products mainly because it is, as Antonio pointed out, still essentially a beta OS.
    Undoubtedly, the Autodesk product family will run under Windows 8 at some point in the future but until then you are on your own....
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Valued Mentor
    09-19-2012 04:50 AM in reply to: fayoud
    Windows 8 is no longer Beta, the RTM version is available to certain people (MSDN members for example).
    Although I had no problem installing C3D 2013 on Win8 I did have the same problem you are having with installing C3D 2012.
    Here's what I had to do.
    Copy all the installer files from the DVD onto my local harddrive.
    Install .NET 2.0 from MS website
    Open the "Setup.ini" file at the root of the DVD content
    Delete section from #============= DOTNET Begin =============== to #============= DOTNET End ===============
    Save Setup.ini file
    Run Setup.exe
    As a side note, i've run into problems on Win8 installing various programs that try to install various versions of the Microsoft Visual C++ 20XX SP1 Redistributable. When this happens I've been able to fix the problem by downloading and installing the redistributable straight from Microsoft then reinstalling the problem program.
    Mike Robertson
    FL. Dept. of Transportation
    CADD Applications Developer
    HPxw4600 Workstation
    Core 2 Duo 2.33ghz, 8gb RAM
    nVidia Quadro FX1700
    Win7 64bit
    *Expert Elite*
    neilyj
    09-19-2012 04:59 AM in reply to: michael.robertson
    Beta or RTM version - makes no difference, still not an officially supported OS:smileyhappy:
    Whilst you are to be applauded for your workaround, i'd suggestt that is a bit much to expect an "ordinary Joe" to be able to know what to do.
    I'd guess the 2013 product family are pretty much Windows 8 ready but as for previous versions........:smileyfrustrated:
    neilyj
    Valued Mentor
    09-19-2012 05:02 AM in reply to: fayoud
    Not supported, true, will be used any way, I'm sure.
    Put it out there for IT or Developer types that have to test before Win8 is released to the general public.
    Mike Robertson
    Win7 64bit
    Active Member
    fayoud
    09-22-2012 10:04 AM in reply to: antoniovinci
    *Expert Elite*
    antoniovinci
    09-22-2012 04:39 PM in reply to: fayoud
    Merci, monsieur Fayoud (vous parlez italien aussi, n'est-ce pas..?)
    Valued Contributor
    bo.martin
    09-24-2012 05:56 AM in reply to: fayoud
    I've had C3D running on 8 RTM since day 1 of the release.
    It isntalled fine. Make sure all user access control is turned off.
    FYI...
    Windows 8 boots faster, resumes from sleep faster, has better dual monitor support
    You just have to look as the new interface as you start menu instead of go WTF is this :smileyhappy:
    Once your to the desktop it's practicly the same (sans the Start Menu)
    If you need a start menu install Start8 from stardock.
    Valued Mentor
    09-24-2012 06:33 AM in reply to: bo.martin
    I too had no problem getting 2013 on Win8, I did have a problem with 2012 though where the work around I noted fixed it.
    I agree with you on the Win8, once you realize you have a start screen instead of menu there really is no huge differences except a faster more secure machine. Everyone talks about the interface but there is a lot of behind the scenes changes that were made that make it faster and more secure.
    Mike Robertson
    Win7 64bit
