• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Autocad Civil 3D - problem in alignment numeration
    218 Views, 1 Replies
    09-21-2012 01:51 PM
    Hey guys,
    I’m new in this fórum and I have a problem with Autocad Civil 3D. I have created an alignment by a polyline, have put arcs and tangents and a Label for identify the number of each Arc and Tangent, as the image shows, but has a section that the numbering is wrong, instead of being 24, 25, 26, 27, 28, 29, 30, 31, became 24, 25, 28, 27, 30, 31 ...
    I try change somethings, but aparently the Autocad Civil don’t know how count sometimes, I hope you know a solution of my problem.
    And as you should have seen, I don’t speak English a lot… Just in complicated situations. hehe
    Thank you.
    Mauricio Sibulski
    Please use plain text.
    sboon
    Re: Autocad Civil 3D - problem in alignment numeration
    09-22-2012 09:08 AM in reply to: mauricio.sibulski
    The label and curve tags are numbered in the order they're created.  You can renumber them to suit your needs.  Check the help files at the link.
    http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-11B62A91-11FC-4D47-BFEE-886D61D7FA9-2142.htm#G...
