• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Accepted Solution
    AutoCAD toolbars in Civil 3D 2012?
    1283 Views, 6 Replies
    06-14-2011 10:08 AM
    I can't get the AutoCAD toolbars (Draw, Modify, etc) to come up in Civil 3D 2012.  I can right click in the side area and I see AutoCAD, AutoCADWS, CIvil, but nothing comes up for AutoCAD.  And under the View tab of the Ribbon, and under Toollbars, I don't even see AutoCAD under there.  Anybody know how to get those back?
    Charles
    Civil 3D 2012
    Win 7 Ultimate x64
    Intel Core 2 3.2Ghz - 12MB RAM
    Nvidia 8500GT Dual DVI
    Please use plain text.
    randcdavidson
    Re: AutoCAD toolbars in Civil 3D 2012?
    06-14-2011 10:31 AM in reply to: ChazBraz
    ?? you say AUTOCAD. If AUTOCAD comes up it should have all the command toolbars that you need.
    Valued Contributor
    06-14-2011 10:33 AM in reply to: randcdavidson
    Theres nothing under AutoCAD - all the others, the list of toolbars comes up, but nothing shows up forAutoCAD
    Charles
    Civil 3D 2012
    Win 7 Ultimate x64
    Product Support
    AlmasSuljevic
    06-14-2011 11:52 AM in reply to: ChazBraz
    Can you switch your Workspace (2D Drafting & Annotations) and see if you can access any of those this way. Also set MENUBAR to 1 to see menus. WS.png
    If you still cannot see these toolbars then you may need to go into your CUI dialog and reset your CUI in Customize tab of the CUI dialog by rt-click on CIVIL. I hope this helps.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    Valued Contributor
    06-14-2011 12:01 PM in reply to: ChazBraz
    That fixed it - I was able to access them from the Tools menu, and can now access it from the right click in the side area in the Civil 3D workspace now as well as from the Ribbon.  I also got out and restarted it - the first time I tried was the first time I had run the program after installing, so maybe everything just hadn't finished compiling...  Thanks for the help!
    Charles
    Civil 3D 2012
    Win 7 Ultimate x64
    New Member
    02-12-2013 07:35 AM in reply to: AlmasSuljevic
    I am bringing AutoCAD toolbars into Civil 3D from the View menu on the right side, but they are locked and I am unable to move them from wherever they come up. How can I unlock the location of the toolbars?
    Thanks!
    *Expert Elite*
    02-12-2013 07:52 AM in reply to: ThereseWeick1906
    If you right-click on a toolbar there should be the Lock Location option near the bottom.
    Or what I do: leave them locked, but you can hold down Ctrl on the keyboard if you want to move them.  This prevents moving them accidentally.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
