• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    AutoCAD Exchange Apps in Civil 3D - Ribbon Mess up
    422 Views, 8 Replies
    07-16-2012 04:57 PM
    I have installed a number of Exchange Apps to my AutoCAD 2013 (part of Infrastructure suite Premium) - all loads nicely on to the plug-ins panel.
    Back in Civil 3D 2013 however, each tool has been given its own add-ins, or plug-ins ribbon panel - not very useful after installing about 20 apps so now have 20 individual ribbon panels with a single tool on each.
    How to combine them back to what AutoCAD 2013 has one  -all on the single plug-ins panel?
    Please use plain text.
    *Expert Elite*
    neilyj
    Re: AutoCAD Exchange Apps in Civil 3D - Ribbon Mess up
    07-16-2012 11:58 PM in reply to: StephenMark
    This is a great question - I've got this annoyance in 2013 as well.
    I suspect there won't be an easy fix though......
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    *Expert Elite*
    DarrenP
    07-17-2012 06:42 AM in reply to: neilyj
    me 2
    Valued Mentor
    TerryDotson
    07-17-2012 08:58 AM in reply to: StephenMark
    They were informed of that in the Beta cycle well before 2013 was released, but it apparently remains broken.
    *Expert Elite*
    DarrenP
    07-17-2012 09:05 AM in reply to: TerryDotson
    it seems to be across all 2013 autocad based products
    Valued Mentor
    TerryDotson
    07-17-2012 04:28 PM in reply to: DarrenP
    Across all verticals, but base (vanilla) AutoCAD works, they all show line up in one Plug-Ins tab.
    Distinguished Contributor
    08-14-2012 12:10 AM in reply to: neilyj
    It's actually not a difficult fix. The problem is that the Civil 3D Add-ins tab is somehow not properly configured. The solution is to simply add a new ribbon tab to your main CUI (must be the main CUI and not the enterprise). Either copy the ribbon tab from a proper ACAD.cuix or just create one with the name Plug-ins with an alias of ID_ADDINSTAB (see attached image). Now add that tab to your desired workspaces. I don't think you can simply rename the Civil 3D Add-ins tab; I recall having mixed results doing that.
    The not so easy part of the solution is to get the plug-ins that you have already installed sorted out. This can be accomplished by one of two ways. Either manually editing the main CUI to remove the plug-in ribbon tabs (and panels) from all the workspaces (might as well get rid of the useless Civil 3D Add-ins tab too), then adding back in all the ribbon panels which should now be merging as expected. The easier solution is to just unload all the partial plug-ins CUI files, then restart Civil 3D and all of the plug-ins should load back up merged into the 'correct' Plug-ins tab.
    This problem was around in 2012 too and I'm pretty sure I filed a report about it. It's really a straight forward fix so it's a shame it wasn't sorted out before pushing 2013 out the door.
    *Expert Elite*
    neilyj
    08-15-2012 12:24 AM in reply to: tyronebk
    Great catch - this seem to work just fine:smileyhappy:
    neilyj
    Active Member
    stevenh0616
    01-02-2013 06:59 AM in reply to: StephenMark
    Augusto Goncalves had a great post explaining the issue for Civil3D. See this link below:
    http://adndevblog.typepad.com/infrastructure/2012/12/duplicated-add-ins-tab-on-civil-3d.html?utm_sou...
    Steve
    Windows 7 Enterprise 64-bit SP1
    Intel Core i7 CPU X920 @ 1.73 GHz
    16.00 GB RAM
    Civil 3D 2013 SP1 64-bit
    Check out my AutoCAD, Civil 3D, and Map Apps on the Autodesk Exchange Store at: Autodesk Exchange Store or Red Transit Consultants, LLC Website
