• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Re: AutoCAD Civil 3D ®2013 Service Pack. --> Please tell me one is due out so
    09-19-2012 07:43 AM in reply to: gjcbachman
    Are you both referring to DText Text Masks? Like with wipe out frames? Or actual Civil 3D object labels that are not appearing correctly?
    Paul R. Mascaro
    CAD Supervisor | Engineering Design
    ENVIRON International Corporation
    System: Dell 6600M
    OS | MS Windows 7 64-bit SP1
    CPU | Intel Core i7 @ 2.70GHz
    RAM | 8.00 GB DDR3 1600 MHz (Dual-Channel @ 798MHz)
    Graphics | NVIDIA Quadro 5010M (4 Gig)
    Please use plain text.
    Active Contributor
    gjcbachman
    09-19-2012 07:48 AM in reply to: pmascaro
    I haven't noticed it with Mtext masking just with Civil 3D labels and a custom bubble attribute block that I use in the multileader.  The masking in the C3D label turns a reddish color and the solid hatch that is color 255 in the block turns cyan (the same color as the attribute text).  So far this happens to both in the same drawing.  It only happens to the bubble block in the multileader not if it is inserted into the drawing as a regular block.  I've just started using the multileader in the last couple of months, prior to that I had never had either problem.
    Lisa
    Windows 7 x 64
    AMD Phenom II X4 945 3.00 GHz
    16 GB RAM
    NVIDIA Quadro 2000
    Civil 3D 2013 (G.114.0.0, SP1)
    09-20-2012 07:02 AM in reply to: pmascaro
    I'm having almost all the above issues too.  What happen to the hotfix 2 that was posted?  I did install it, but nothings changed.
    Valued Contributor
    09-26-2012 07:52 AM in reply to: sharshbarger
    Paul R. Mascaro
    System: Dell 6600M
    Valued Contributor
    10-05-2012 11:54 AM in reply to: pmascaro
    1/2 hr to copy and paste some AutoCAD Nodes (Not C3D Points) a few poly lines and some text from 1 drawing to another.
    Paul R. Mascaro
    System: Dell 6600M
    Valued Contributor
    11-20-2012 02:22 PM in reply to: pmascaro
    Any news???
    This is ridiculous that I have to crash out of civil 3D and open map 3d to copy and past or bind an xref....
    Grrr....
    Paul R. Mascaro
    System: Dell 6600M
    DarrenP
    11-29-2012 11:29 AM in reply to: pmascaro
    its out now
    you can only get it through the commication center in Civil 3d
    attached is the read me
    Valued Contributor
    11-29-2012 11:48 AM in reply to: DarrenP
    Thanks! Would you mind providing a link? I can't find it anywhere....
    Paul R. Mascaro
    System: Dell 6600M
    DarrenP
    11-29-2012 11:49 AM in reply to: pmascaro
    read above thread
    it hasn't been posted to the autodesk website yet
    Valued Contributor
    11-29-2012 11:50 AM in reply to: pmascaro
    Nevermind, I found it by logging in through my Civil 3D for a live update.
    Paul R. Mascaro
    System: Dell 6600M
