• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    AutoCAD Civil 3D 2013 PROFILE BAND DOESNT FIT INTO VIEWPORT, PLEASE NEED HELP
    395 Views, 6 Replies
    10-28-2012 01:20 PM
    I have created a plan and profile drawing on my sheet but the profile band is out of the viewport. how  can i also align the plan and the  profile   to alight  to the left or how can  i make the plan and  profile to fit inside the  the viewport.
    PLEASE SEE  THE PICTURE BELOW
    Please use plain text.
    Valued Contributor GZE
    Valued Contributor
    Re: AutoCAD Civil 3D 2013 PROFILE BAND DOESNT FIT INTO VIEWPORT, PLEASE NEED H
    10-28-2012 02:03 PM in reply to: jesseyusufu
    It happened to me as well. Alignning plan and profile at the center solved my problem
    Humphrey GZE
    Civil 3D 2013 64bit SP1
    Elitebook 8540w
    Core i7 2.8GHz, 8Gig RAM
    NVIDIA Quadro FX880
    160Gb SSD
    10-28-2012 02:13 PM in reply to: GZE
    GZE Please how do i align the plan and profile to center so everything fits into the viewport. THANKS
    10-28-2012 11:08 PM in reply to: jesseyusufu
    i have found the solution after sleepless night. I didnt know that i simply need to create a buffer profile band and that did the margin thank you all
    Valued Contributor
    10-28-2012 11:45 PM in reply to: jesseyusufu
    What is a buffer profile band? Kindly explain
    Humphrey GZE
    Elitebook 8540w
    NVIDIA Quadro FX880
    160Gb SSD
    10-29-2012 10:01 AM in reply to: GZE
    a buffer profile band is simply a normal profile band that you create with no title band and everything other band property is  set to null except that the title length and width is set so as to provide the necessary space. the picture below shows the result i got
    10-31-2012 06:41 AM in reply to: jesseyusufu
    Hi all of you civil 3d gurus. my next challenge is how can i separate the profile view height from the viewport. My profile view height as you can see from the photo above is hidden at the top in the viewport. PLEASE I NEED YOUR HELP
