• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    AutoCAD Civil 3D 2012 Toolbars instead of Ribbon
    399 Views, 4 Replies
    02-22-2012 11:14 AM
    I'm getting ready to install AutoCAD Civil 3D on my computer and I like using the AutoCAD classic toolbars instead of the newer ribbon.  Does AutoCAD 2012 still have the classic toolbar that you can switch to?
    Thank you.
    Distinguished Mentor
    Re: AutoCAD Civil 3D 2012 Toolbars instead of Ribbon
    02-22-2012 11:58 AM in reply to: mramseur
    Why not just use the "menubar" in addition to the Ribbon.  You will miss out on commands that are only available in the Ribbon.
    Bill
    Windows 7 x 64
    Nvidia GeForce 9800 & 8500
    12 GB Ram
    i7 965 @ 3.20 GHz
    Civil 3D 2012 SP 1
    Civil 3D 2013
    Valued Mentor
    02-22-2012 12:57 PM in reply to: wfberry
    Fully agree, if you are not using the ribbon you will miss out on newer C3D commands (unless you somehow memorize every C3D command).
    If you don't like the screen space of the ribbon it can be minimized where it takes up the same amount of room as a menu.
    Mike Robertson
    FL. Dept. of Transportation
    CADD Applications Developer
    HPxw4600 Workstation
    Core 2 Duo 2.33ghz, 8gb RAM
    nVidia Quadro FX1700
    Win7 64bit
    **Master
    AllenJessup
    02-22-2012 01:25 PM in reply to: mramseur
    It does. But as the others did I recommend you leave the Ribbon open but minimizes. I was never a fan and get around it by creating ToolPaletts for different tasks. You can add any Civil 3D command you want to a ToolPalette.
    The thing I do like about the Ribbon is that it is context sensitive. That means that if you select a Civil 3D object. It will automatically open a Ribbon tab with object specific commands. If you select a Featureline the tab will contain command specific to Featurelines. Likewise Surfaces, Corridors, Profiles etc.
    Allen
    Active Contributor
    JessicaPalmer
    02-22-2012 06:58 PM in reply to: mramseur
    If I understand your original question you are looking to add the toolbars but not replace the ribbons. On the View tab, at the far right hand end, is a toolbar button. First click toolbar, then choose the category and the specific toolbar to turn on.  You can place them where ever you wish.
    Continue to use the Ribbon for new commands you may find that it is easier to use than some of the toolbars.
    :smileyhappy:
    Jessica Palmer
