• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    wes
    New Member
    AutoCAD C3D 2013 Parcel question?
    133 Views, 2 Replies
    11-27-2012 04:20 AM
    • I am having a problem with my area calcs in the Parcel creator. Who should I talk to? The guys in my office say to just do the calcs the old way. My thought is that we all just installed the C3D 2013 infrastructure design programs and we need to figure out how to use it fully. I simply need to find out who is the guru in this area so that I can get some training on the program.
      I am doing a 2500 acre survey and dividing it up into four tracts due to inheritance issues. When I calculate the boundary of each tract and convert to a Parcel by object "polyline", the acreage is slightly larger than when I do a regular "key in the call" mapcheck for closure. I have the job set up in nad 83 state plane central texas. I can not find a scale factor in the drawing settings that I think should fix the issue.
      Any help would be great,
      Wes
    Please use plain text.
    *Pro
    Re: AutoCAD C3D 2013 Parcel question?
    11-28-2012 01:19 PM in reply to: wes
    some of your lines have a z elevation other than zero.   This may be throwing off the calculation.
    also i'm not sure if us survey ft  instead of international ft has anything to do with it.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Valued Contributor
    Pointdump
    11-28-2012 02:55 PM in reply to: wes
    Wes,
    Try flattening your points to elevation, thusly:
    You'll need to do that on each of your point styles. For more info, check here:
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Flatten-point-styles-to-elevation/m-p/3630018/highlig...
    Dave
    Mohave Valley, Arizona
    HP Pavillion dv9000
    Intel Core Duo @ 1.86 GHz
    nVidia GeForce Go 7600
    3 GB Ram
    32 Bit Windows Vista
    Civil 3D 2010
