• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    wsargent
    Re: $Audit-Bad-Layer$
    07-27-2012 07:27 AM in reply to: mccabejoshua
    mccabejoshua wrote:
    I don't like leaving those errors in my drawing.  I have been in that cycle as well but it occurs rarely now since I purge>audit>purge>audit regularly.  If the "cycle" occurs I can trace the cause quickly and resolve it.
    How are you able to trace this?
    __________
    Dell Percision T3500:
    MS Windows 7 64-bit SP1
    Intel Xeon CPU W3505 @ 2.53GHz, 12.00 GB RAM, NVIDIA Quadro 600
    Please use plain text.
    mccabejoshua
    07-27-2012 10:23 AM in reply to: wsargent
    I audit and purge basically after I do anything.  If I get the bad layer I know it is a result of what I just did.
    To clarify, I saw this a lot when I was building our template and assigning layers to label styles, point styles, etc.  When it occured I generally knew what needed to be fixed.
    If I remember correctly I had corrupted blocks that had layers other than "0" in built into them but nothing on them.  For example, I would have a sewer manhole and when I tested the block it would have a few random layers in the block that I could not purge.  When I brought the block in, it would also bring in the random unused layers.  I could then purge them but the audit created the "bad layer".  I knew it was the blocks because that is what I was working on.
    mccabejoshua
    07-27-2012 10:44 AM in reply to: wsargent
    My first step would to audit>purge>audit a blank template drawing as suggested in a previous post.  When I do this to my template there are no errors and nothing to purge.
    *Expert Elite*
    07-30-2012 06:33 AM in reply to: mccabejoshua
    Nothing to purge in your template?  Do you have no Blocks, Layers, Dim Styles, Text Styles set up for yourself in there?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    mccabejoshua
    07-30-2012 07:17 AM in reply to: troma
    I have all these.
    wsargent
    07-30-2012 07:18 AM in reply to: wsargent
    I have checked all 12 template files and none returned any errors, but I am not able to purge theses files because there are a lots of styles, blocks, layers, etc. that need to be maintained in the file for the drafter. I have opened read-only copies of the files and audit/purged/audited the read-only files with no errors.
    Does that mean that the errors are being created by the users?
    __________
    mccabejoshua
    07-30-2012 07:43 AM in reply to: wsargent
    I'm not sure where the error is being created.  The good news is that your not starting with the errors.  Trying to recreate the error will be time consuming and a total pain but once its found you will also have to figure why its causing the bad layer and figure out how to fix it, if you can't work around it.
    Are you purging unused layers at the end of the day after the audit?  If yes, I believe you may have a block, style, etc that calls for a layer that is no longer there, thus creating a bad layer condition.(or something similar)
    I would like to know if Autodesk has list of conditions that will cause the "bad layer", I assume it would be rather large.  I assume this not specific to Civil 3D and can happen with any Autodesk product that allows you to audit your drawing.
    I wish I could help more.  Please keep us updated if you find the cause/reason.
    *Expert Elite*
    Neilw
    07-30-2012 08:03 AM in reply to: mccabejoshua
    This is just a shot in the dark; have you purged REGAPPS? It may be that something has come into your drawing from a foreign product. I've seen this type of behavior when working with DWG's exported from Microstation based products.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    *Pro
    07-30-2012 08:27 AM in reply to: Neilw
    Audit -> Purge -> Save -> Close -> Re-Open, and the audit bad layer will be gone
    *Expert Elite*
    08-09-2012 06:02 AM in reply to: murray-clack
    One more note: save before you audit.  I've crashed and burned a few times on that.
