• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    At volume calculation program Autocad Civil 3d 2011 takes off
    1135 Views, 3 Replies
    11-10-2010 08:32 PM
    Good afternoon all! I had a problem. I work in Autocad Civil 3d 2011. Has created two surfaces from groups of points. I create the third surface "Surface TIN for volume calculation". The program works normally, the volume in properties of a surface pays off. But as soon as I create the fourth surface "a surface for calculation of volumes of quadras." The program or takes off or gives out an error, depending on grid parameters. For example, grid parameters I take 25м*25м, the program long thinks and the window "an error takes off at surface creation". If I choose grid parameters 5м*5м - the program writes "a fatal error. There is not enough memory - appendix closing" also takes off. Prompt, in what a problem and how it to solve?
    Please use plain text.
    Employee
    Re: At volume calculation program Autocad Civil 3d 2011 takes off
    11-11-2010 07:43 AM in reply to: m45bgz
    I believe you need to install Civil 3D 2011 Update 1. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15755400&linkID=9240698
    There was a grid volumes issue that was fixed in the Update. This is from the Issues Resolved list:
    Surface
    • Changing the visual style of a drawing which contains a surface no longer causes AutoCAD Civil 3D to close unexpectedly.
    • AutoCAD Civil 3D no longer becomes unresponsive when creating a Grid Volume Surface.
    Matt Blanchard
    Autodesk, Test Development
    11-11-2010 09:42 PM in reply to: m45bgz
    Thank you very much, blanchm. Your answer has helped. The program has calculated all volumes. A question I close.
    New Member
    wojtekmm13
    06-09-2011 01:57 AM in reply to: blanchm
    I have some problems with this update. I have install it and now I can not open my files whichI have done before update and containing a point cloud. If it is possible please help. Sorry for my English but I am from Poland and I don't know it perfect.
