AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Assembly not showing in cross sections
- Highlight
- Email to a Friend
I have everything needed for plotting of cross sections. Alignment, profile, assembly....
The "Corridor Section Editor" shows everything as it should be. Existing Ground, Final Grade, Labeling, etc...
When "Create Multiple Views" or "Create Section View" only existing Ground shows. All layers are on...
Any ideas..
Re: Assembly not showing in cross sections
- Highlight
- Email to a Friend
BTW When plotting sections, in the "Section Display Option" Existing ground is the only thing showing, what am I missing, Thanks
- Highlight
- Email to a Friend
Have you sampled the corridor? Under group properties, the sections tab has a 'sample more sources' button (top right had corner) open it up and you will be able to add or remove objects to your section views.
- Highlight
- Email to a Friend
That was it! Something simple as usual!!
Thanks!!
