• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Accepted Solution
    Assembly not showing in cross sections
    218 Views, 3 Replies
    01-21-2013 07:39 AM
    I have everything needed for plotting of cross sections. Alignment, profile, assembly....
    The "Corridor Section Editor" shows everything as it should be. Existing Ground, Final Grade, Labeling, etc...
    When "Create Multiple Views" or "Create Section View" only existing Ground shows. All layers are on...
    Any ideas..
    Please use plain text.
    Member
    Re: Assembly not showing in cross sections
    01-21-2013 07:40 AM in reply to: audave
    BTW When plotting sections, in the "Section Display Option"  Existing ground is the  only thing showing, what am I missing, Thanks
    Active Member
    Wanita17
    01-21-2013 10:12 AM in reply to: audave
    Have you sampled the corridor?  Under group properties, the sections tab has a 'sample more sources' button (top right had corner) open it up and you will be able to add or remove objects to your section views.
    Member
    01-21-2013 10:57 AM in reply to: Wanita17
    That was it! Something simple as usual!!
    Thanks!!
