• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    taneum
    Assembly Transitions.................
    199 Views, 6 Replies
    11-14-2012 06:27 AM
    This was so freaking easy in Eagle Point bus sure enough, it's either buried in C3D or you cannot do it.  I have two retaining wall assemblies running along my alignemnt.  I just used generic links to show the face of the wall, the swale at the top of the wall, and the daylight from the swale to the existing ground.  Anyways, I have to different assemblies and I have an area of about 42' between them that I want transistioned.  This needs to show up in the cross sections as well, not just the corridor.  I cannot find anywahre in C3D to do this.
    Help please!
    Please use plain text.
    *Expert Elite*
    Re: Assembly Transitions.................
    11-14-2012 06:36 AM in reply to: taneum
    A picture of what you are describing would go a long way in helping us visualize what you need.
    Many generic links can be set to target horizontal and/or vertical objects. This is one way to get a transition as you've described.
    Jeff_M, also a frequent Swamper
    Valued Contributor
    taneum
    11-14-2012 06:52 AM in reply to: Jeff_M
    How would links work if I am out of range in my regions.  I understand how links work but one region contains an assembly which runs from station 3+00 to 3+38.  Another region contains a different assembly that runs from 3+60 to 6+25.  I just need to run a straight transition from 3+38 to 3+60.
    *Expert Elite*
    Neilw
    11-14-2012 07:25 AM in reply to: taneum
    I think you'll need to design an assembly using links that can target a point or feature. Then draw the transition lines in plan and use those as targets for the links.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Valued Contributor
    taneum
    11-14-2012 07:28 AM in reply to: Neilw
    Yeah I am looking into that.  I am going to try a couple things right now.
    Valued Contributor
    taneum
    11-15-2012 08:07 AM in reply to: taneum
    I created another assembly like you noted and it seems to be doing alright.  However, while my curb tapers, the wall behind actually cuts straight back and then matches back up with the curb as to make a landing area behind the curb.  I have target lines back there for my sub assemblies to target.  This is all working fine and dandy for my sections, as for the corridor surface, not so much.  Where my wall target lines basically go 90 degrees back from the curb to vreate this landing, the contours are not recognizing the corridor in this area.  When I turn on the triangles for my corridor surface, they are jumping accross those target lines the the corridor uses.  Why do my sections look okay but not the contours?  Everywhere where the target lines pretty much parallel my alignment and curb and gutter, the contours work well but in this one spot where the target lines run perpendicular, back away from my curb and gutter, the contours jump the corridor lines.
    On a side note, the "perpindicular" lines are actually at about 89.5 degrees incase the software didn't like perpindicualr lines but that didn;t help at all.
    In the .pdf, the red lines are my target lines
    My asseembly is made up of "generic linkwidthandslope" sub-assemblies that target these lines.
    Michael
    Valued Contributor
    taneum
    11-15-2012 08:33 AM in reply to: Neilw
    I think I figured out my issue.  When I go into the corridor properties and go to the surface tab, when you create the surface you have to tell C3D what to create it from, links or feature lines.  I am using links but the boxes were left unchecked for the "Add As Breakline" column.  I checked them all and now it looks real nice.
    Michael
