AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Assembly Transition s......... ........
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This was so freaking easy in Eagle Point bus sure enough, it's either buried in C3D or you cannot do it. I have two retaining wall assemblies running along my alignemnt. I just used generic links to show the face of the wall, the swale at the top of the wall, and the daylight from the swale to the existing ground. Anyways, I have to different assemblies and I have an area of about 42' between them that I want transistioned. This needs to show up in the cross sections as well, not just the corridor. I cannot find anywahre in C3D to do this.
Help please!
Re: Assembly Transition s......... ........
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A picture of what you are describing would go a long way in helping us visualize what you need.
Many generic links can be set to target horizontal and/or vertical objects. This is one way to get a transition as you've described.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How would links work if I am out of range in my regions. I understand how links work but one region contains an assembly which runs from station 3+00 to 3+38. Another region contains a different assembly that runs from 3+60 to 6+25. I just need to run a straight transition from 3+38 to 3+60.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think you'll need to design an assembly using links that can target a point or feature. Then draw the transition lines in plan and use those as targets for the links.
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yeah I am looking into that. I am going to try a couple things right now.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I created another assembly like you noted and it seems to be doing alright. However, while my curb tapers, the wall behind actually cuts straight back and then matches back up with the curb as to make a landing area behind the curb. I have target lines back there for my sub assemblies to target. This is all working fine and dandy for my sections, as for the corridor surface, not so much. Where my wall target lines basically go 90 degrees back from the curb to vreate this landing, the contours are not recognizing the corridor in this area. When I turn on the triangles for my corridor surface, they are jumping accross those target lines the the corridor uses. Why do my sections look okay but not the contours? Everywhere where the target lines pretty much parallel my alignment and curb and gutter, the contours work well but in this one spot where the target lines run perpendicular, back away from my curb and gutter, the contours jump the corridor lines.
On a side note, the "perpindicular" lines are actually at about 89.5 degrees incase the software didn't like perpindicualr lines but that didn;t help at all.
In the .pdf, the red lines are my target lines
My asseembly is made up of "generic linkwidthandslope" sub-assemblies that target these lines.
Michael
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think I figured out my issue. When I go into the corridor properties and go to the surface tab, when you create the surface you have to tell C3D what to create it from, links or feature lines. I am using links but the boxes were left unchecked for the "Add As Breakline" column. I checked them all and now it looks real nice.
Michael
