• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    phareouh
    Accepted Solution
    Assembly Overlap , When Assigning Targets for median in corridor
    124 Views, 1 Replies
    07-09-2012 08:48 PM
    Dear All
    Here's my assembly :
    and
    when I tried to assign the Median Width in my corridor to a polyline representing media width,
    I got this overlap in my Section view :
    so how can I maintain Objects in this cause "Lanes" attached to median no matter width change ?
    Yeah Will Not that much :
    Sony VPCCW26FA
    Intel Core i5 M 520 @ 2.40GHz
    8192MB RAM
    NVIDIA GeForce GT 330M 512MB Dedicated
    Please use plain text.
    *Expert Elite*
    BrianHailey
    Re: Assembly Overlap , When Assigning Targets for median in corridor
    07-10-2012 05:49 AM in reply to: phareouh
    Most likely what happened is you attached the lane accidentally to the assembly baseline and not the median. You then moved the lane subassembly to the correct location. When you do that, it's still attached to whatever it was originally attached to but now with an offset. Grab your lane (and everything left of it for the left side) and on the ribbon choose the command MOVE. Don't use the AutoCAD MOVE, COPY, or MIRROR command unless you don't want to change what the subassembly is attached to.
    http://screencast.com/t/W08ZOH2oMC
