AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Are you experienci ng recurring crashes? If so, we'd like to hear from you.
- Highlight
- Email to a Friend
We just upgraded to 2013 Civil 3D from 2011 Civil 3D. We sometimes work with large files (40mb to 60mb), and had been having problems with Autocad crashing. We had good luck upgrading our computers, which solved almost all of our problems while we were using 2011.
Since we've upgraded to 2013 Civil 3D, we're back to the same problem. Autocad freezes, then crashes (seemingly at random). Typically we don't even have a crash report. It's only with larger files, but our computers should not be the problem. It's very frustrating as we lose a lot of time that we don't have. Even if Autosave recovers some of our work, we have to figure out what wasn't saved.
Please let me know if there's anything I can do to help solve this problem. Thanks.
Justin
- Highlight
- Email to a Friend
Good morning Karen
I was having challenges with C3D13 crashing when closing the program.
My friend Seth in Manchester suggested applying this hotfix: http://usa.autodesk.com/getdoc/id=DL20100771
So far so good...
Hope this helps others.
- Highlight
- Email to a Friend
Afternoon Karen,
Hopefully you're still doing this. I"m having severe issues with Civil 3D 2013. Issues like crashes during save at 93%, after I've replaced a structure or a style of a structure, or just flat out moved the structure in pipe networks. Doesn't matter what I do it crashes.
Also Pressure networks issues causing save issues as well. So it's not just a Pipe network issue.
If you can help please let me know.
Heidi B.
Yes I'm filing a CER every time it happens.
- Highlight
- Email to a Friend
Hi Heidi,
I would be happy to take a look at what might be going on. Would you mind if we corresponded by email rather than on this thread?
Please email me at karen.dowling@autodesk.com and we can begin.
Karen Dowling, Quality Analyst
Autodesk, Inc.
Karen Dowling
Sr. Quality Analyst
Autodesk, Inc
- Highlight
- Email to a Friend
Given the current Cloud "buzzwords" and direction that Autodesk seems to be going, its a great shame that when attempting to access 360 in Civil 3D I get a crash every time. I have raised a support ticket but no resolution and have submitted all the CER's.
I have got a swf video of what happens but can't upload to this forum
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Highlight
- Email to a Friend
I have crashes using using Civil 3D 2013 with
1. The AUDIT command, the software just hangs up.
2. With Trimble Link, I just have to press the export surface button, and AutoCAD crashes. Other Trimble Link functions act the same way, it only takes a few more button pushes, dialogs etc to get to the crash.
3. I've had crashes dragging cogo point labels.Seems to occur with points that have no elevation, but the label style includes an elevation field.
4. Some drawings just seem to get crashy, running a RECOVER works if the report indicates errors found, if no errors reported the problem hasn't been solved so I start a new drawing and copy drawing elements bit by bit, save over the old drawing and the crashing stops.
Have to admit I stopped completing the crash reports years ago because of no feedback ever, eventually just believed they went into a bit bucket at Autodesk, so why bother.
Generally a lot of the progress indicators seem to have been removed, and I sometimes don't know whether the software has hung up or is just taking a while to work through a task.
Previously used to run AutoCAD 2012 on a HP Pavilion DV7 2014tx 8GB RAM 2x500GB HDDs, Win7, purchased August 2009.
I've now moved to a Clevo Metabox using an Intel i7 3720QM 2.6Ghz 8 core, 16GB RAM, Nvidia GeForce GTX 680M 4GB, 256GB SSD and second 740GB hybrid drive.
Apart from a startling improvement in start-up time for AutoCAD Civil 3D from 2 minutes+ down to about 15 seconds, the crashes have reduced down to an (equally startling) less than 10% (!!) of what I experienced before, to the point where (apart from the Trimble Link BS) crashing is not really a major problem as was the case with for example the Civil 3D 2007 release.
Guess I'm saying bad hardware does have an effect, something I never really appreciated before. The previous Hewlett Packard hardware I had was just substandard, the machine cost me $3700 at the time, just took for granted it was a good machine.
We have 8 Dell computers with I5 processors, 8GB RAM running Civil 3D in my survey office with some crappy video cards, not ideal machines, but somehow I get far less reports of crashing than expected.
Just my two cents worth.... Don’t know if it helps.
Hans Moller
Lead Surveyor
Bechtel GLNG Plant, Gladstone Australia.
+61 7 48368310
hmoller@bechtel.com
Surveying & Management Services
Gladstone Australia
Clevo Metabox 16GB, Intel i7-3720QM 3.1Ghz, 256GB SSD, Nvidia GTX 680M
AutoCAD Civil 3D 2013
