• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    wizengr
    Accepted Solution
    Anyway to convert a group of Lines to Polylines
    379 Views, 7 Replies
    11-01-2012 11:28 AM
    On several occasions I have had to convert a group of lines to polylines but had to select and convert each line one after the other. Instead of one after another is there a way or a command to select all the lines and convert them as group into polylines?
    Please use plain text.
    Active Contributor
    Re: Anyway to convert a group of Lines to Polylines
    11-01-2012 11:35 AM in reply to: wizengr
    Type pedit, select multiple, pick all of the lines you want to convert, type Y when asked if you want to convert them to polylines, exit command.
    *Expert Elite*
    BrianHailey
    11-01-2012 02:30 PM in reply to: wizengr
    Even easier (if you are on 2012 or later - or was it 2011?); Grab the lines and type J at the command line.
    *Expert Elite*
    Joe-Bouza
    11-01-2012 02:57 PM in reply to: BrianHailey
    and get what?
    I'm left with lines. Is there more to it?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Valued Contributor
    11-02-2012 11:16 AM in reply to: wizengr
    To convert the lines into polylines, they have to be touched end to end .  the pedit command will turn the series of lines into one pline, not multiple
    Surveyor Lee
    *Expert Elite*
    Joe-Bouza
    11-02-2012 11:19 AM in reply to: SurveyorLee
    Thats only to join them. PEDIT M will convert a collection of geometry
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    11-02-2012 11:22 AM in reply to: wizengr
    and if you want to do some cleanup don't forget you have the Map3D-functionality included, therefor the command _MAPCLEAN (>>>details<<<) can help a lot!
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Expert Elite*
    BrianHailey
    11-04-2012 02:44 PM in reply to: Joe-Bouza
    Joe-Bouza wrote:
    and get what?
    My bad. I missread the original question. To join them, use J. To simply convert them, use MPEDIT (you can select them first and then run MPEDIT whereas if you run PEDIT you must select them after the fact).
