• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    JorgeAguilar
    Accepted Solution
    Any Advanced Civil 3D Experts? Specific band problem is driving me mad!
    543 Views, 5 Replies
    07-08-2011 02:51 AM
    We are losing our minds trying to figure out how to fix this issue. We are designing a pipe network several kilometers long and one feature we need to show in the profile view is cover depth ('ground level' minus 'level of top of the pipe'). Everything was working fine and the band (Cover depth) was showing the correct values but a few days ago we opened the drawing again and the values are all '0.00'. We have tried everything we can think of, including expressions, to no avail. Anyone knows how to fix this problem? Any Autodesk people with a few minutes to spare and share their expertise so that I can regain my sanity?
    I am attaching a snapshot to show the band style  / label style / Text component / Properties we are using. There is only one surface (existing ground) and one database (pipe network) that we have created so it is not a matter of choosing a wrong profile or data source.
     Your help will be greatly appreciated.
    Cover depth band.jpgso
    Please use plain text.
    Distinguished Mentor
    Re: Any Advanced Civil 3D Experts? Specific band problem is driving me mad!
    07-08-2011 04:55 AM in reply to: JorgeAguilar
    I'm not going to presume to be an advanced expert.
    You might want to post which version you are using.
    Also for something like this, posting the dwging would be greater help, as it allows people to check through the drawing to locate the problem far easier than try to look at screen shots.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    Member
    JorgeAguilar
    07-08-2011 06:57 AM in reply to: andrewpuller3811
    Thanks for your help Andrew,
    I am using Civil 3d 2011 (British Metric). I am also attaching a significantly trimmed version of the drawing with the issue I mentioned - I had to erase a lot of features and points to comply with the max size for upload so some parts of teh surface are missing in the profile. Again, thanks for your time and help.
    Active Contributor
    07-08-2011 08:08 AM in reply to: JorgeAguilar
    under Prospector>Pipe Networks>Networks>RISING MAN 300-END, select the 'pipes', and under the preview window on the bottom of the toolspace window, select all the pipes in the preview window and scorll to the right until you find 'Reference Surface (you might need to expand the cell to see it)", right click on top of the header 'Reference Surface", Edit..., pick the FINAL SURFACE and you should see the cover depth value.
    Active Contributor
    07-08-2011 08:13 AM in reply to: JorgeAguilar
    Member
    JorgeAguilar
    07-08-2011 08:18 AM in reply to: marcross
    Great Stuff! Thanks a lot. I owe you one.
