• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    hkaplan1227
    Another Point Labels???????
    88 Views, 2 Replies
    02-23-2013 05:58 AM
    With some help from you guys I think i have the whole point label think almost figured out. What I had started to do was to create point groups based on the rotation angles along with point label styles. This seems to be working. Although there is one small issue. But, i'm not sure what it is tied to. I have the survey drawing X-refed and in model space the elevations look fine. But, in the paper space some elevations look as if there rotations reverted back to 0. Not all of the points acted this way though. i believe they are all in one point group also.
    Hopefully you guys understand my problem.
    Any help would be appreciated
    Howard Kaplan, Civil3D 2013
    Please use plain text.
    TRogers
    Re: Another Point Labels???????
    02-23-2013 06:32 AM in reply to: hkaplan1227
    Try changing the properties of the label style under the General tab.  See saved attachment...
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    hkaplan1227
    02-23-2013 07:23 AM in reply to: TRogers
    Thanks, Its was set to "Stacked Text", I changed it to "As Composed" and it fixed the problem.
