• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Landman
    Ambient Settings for Grid Coordinate
    148 Views, 3 Replies
    11-26-2004 08:16 AM
    Under Ambient drawing settings my Grid coordinate is set to unit feet. I wish to change it to m however the setting is locked and I am unable to change it. How do I go about changing it. Thanks
    Please use plain text.
    *Landman
    Re: Ambient Settings for Grid Coordinate
    11-26-2004 02:23 PM in reply to: *Landman
    Problem resolved. Forgot to apply a zone to the project. Also did not have the station unit under ambient settings set to metric." > Under Ambient drawing settings my Grid coordinate is set to unit feet. I > wish to change it to m however the setting is locked and I am unable to > change it. How do I go about changing it. > > Thanks > >
    *Chakri Gavini
    11-27-2004 08:45 AM in reply to: *Landman
    If you are a metric user I would suggest to set your default template as ACADISO.DWT or any other Civil3D metric templates (such as _Autodesk Civil 3D metric By layer' or one of your custom templates). If you have a dwt that started from acad.dwt - you may have to change units for all nodes in the ambient settings (besides changing in the units and zone); and also you have to recompose all your labels styles, as most of the standard styles would have imperial units (as you started dwg from imperial units!) Chakri Autodesk "Landman" wrote in message news:41a7acce$1_3@newsprd01... > Problem resolved. Forgot to apply a zone to the project. Also did not have > the station unit under ambient settings set to metric." > > > Under Ambient drawing settings my Grid coordinate is set to unit feet. I > > wish to change it to m however the setting is locked and I am unable to > > change it. How do I go about changing it. > > > > Thanks > > > > > >
    *Landman
    11-29-2004 03:30 PM in reply to: *Landman
    Thanks. "Chakri Gavini" wrote in message news:41a8af44_3@newsprd01... > If you are a metric user I would suggest to set your default template as > ACADISO.DWT or any other Civil3D metric templates (such as _Autodesk Civil > 3D metric By layer' or one of your custom templates). > > If you have a dwt that started from acad.dwt - you may have to change units > for all nodes in the ambient settings (besides changing in the units and > zone); and also you have to recompose all your labels styles, as most of the > standard styles would have imperial units (as you started dwg from imperial > units!) > > Chakri > Autodesk > > > "Landman" wrote in message > news:41a7acce$1_3@newsprd01... > > Problem resolved. Forgot to apply a zone to the project. Also did not have > > the station unit under ambient settings set to metric." > > > > > Under Ambient drawing settings my Grid coordinate is set to unit feet. I > > > wish to change it to m however the setting is locked and I am unable to > > > change it. How do I go about changing it. > > > > > > Thanks > > > > > > > > > > > >
