• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Alley Corridor
    253 Views, 8 Replies
    12-26-2012 09:23 AM
    Hi All,
    What's the best way to model an alley with a 90 degree angle (turn).  Do I treat it as an intersection with a zero radius?  My typ section is 15 feet width with a 4% slope down to the center of pavement.  "V" bottom.  Not sure how to get it to model the outside corner and also eliminate the inside overlay.  Thanks,
    Please use plain text.
    *Expert Elite*
    Re: Alley Corridor
    12-26-2012 10:19 AM in reply to: trynders
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    Re: Alley Corridor
    12-26-2012 10:38 AM in reply to: trynders
    I don't know if I would necessarily use the Intersection tools, but I would make a multi-baseline corridor to handle this.
    If you're not familiar the feature, a Corridor can have multiple alignments defined as Baselines. Each will have its own design profile and assembly.
    See the attached simple corridor with 90 degree corner.
    Tim Corey, Owner
    Redding, CA
    Valued Mentor
    fcernst
    Re: Alley Corridor
    12-26-2012 06:58 PM in reply to: tcorey
    I don't see the advantage of using a multi-baseline Corridor?
    One baseline, and you would not have to monitor and update the common PVI across two profiles.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Re: Alley Corridor
    12-27-2012 05:47 AM in reply to: trynders
    Thanks tcorey,
    I was going to take a look see but im using 2012 and apparently you attached a newer version.  Sad day.
    Distinguished Mentor
    Re: Alley Corridor
    12-29-2012 03:44 AM in reply to: trynders
    Here is a blog post of mine covering this
    http://andrewscivil3dstuff.blogspot.com.au/2011/06/create-corridor-with-90-degree-bend.html
    and a similar topic with sample drawing is here
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Intersection-Design-90-degree-turn/m-p/3012576
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    Valued Mentor
    fcernst
    Re: Alley Corridor
    12-29-2012 03:50 PM in reply to: andrewpuller3811
    Good show mate!  Let's kick it up a notch..   A mitered interior corner cleanup for the intersection:
    One corridor, one assembly, one profile...fully dynamic.
    Ernst Engineering
    Fred Ernst, PE
    *Expert Elite*
    BrianHailey
    Re: Alley Corridor
    12-30-2012 05:00 PM in reply to: fcernst
    Care to share the drawing Fred? I would love to see your approach to this. I think I know how you did it but I'm not positive.
    *Expert Elite*
    Re: Alley Corridor
    12-31-2012 09:01 AM in reply to: fcernst
    I like Fred's result as he is able to include cross secitons in the mitered area. Do you care to expound?
    Tim Corey, Owner
    Redding, CA
