• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Accepted Solution
    All my drawing colors display as gray
    388 Views, 8 Replies
    09-05-2012 11:24 AM
    I ended my session yesterday, plotted my first layout, everything looks perfect.  I started up today and everything is gray.  Drawing layer colors are correct.  Everything looks ok in the properties pane when I select anything.  Print preview shows everything black.  Never had this happen before.  Solution?
    Mike R.
    Please use plain text.
    *Expert Elite*
    Re: All my drawing colors display as gray
    09-05-2012 11:34 AM in reply to: miker
    Is "Display Plot Styles" checked in the Page Setup? If so, uncheck it.
    Jeff_M, also a frequent Swamper
    Active Member
    09-05-2012 12:03 PM in reply to: Jeff_M
    Box is not checked.
    Mike R.
    *Expert Elite*
    neilyj
    09-05-2012 12:20 PM in reply to: miker
    Occurring in model or paper space or both??
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Active Member
    09-05-2012 01:06 PM in reply to: neilyj
    Both
    Mike R.
    Active Member
    09-07-2012 12:29 PM in reply to: miker
    Change layer setting.  Seems to have worked.
    Mike R.
    Active Member
    09-12-2012 04:05 AM in reply to: miker
    Not checked Michael Robertson CAD and Lab Operations Manager Blackburn Consulting :blocked::mailto:brendaf> Office: (916) 375-8706 Cell: (916) 717-9909 Fax: (916) 375-8709 e-mail: miker@blackburnconsulting.com 2491 Boatman Avenue, West Sacramento, CA 95691 :http:smileyembarrassed::http:smileyembarrassed: www.blackburnconsulting.com:blocked::mailto:brendaf>
    Mike R.
    Active Member
    Both Michael Robertson CAD and Lab Operations Manager Blackburn Consulting :blocked::mailto:brendaf> Office: (916) 375-8706 Cell: (916) 717-9909 Fax: (916) 375-8709 e-mail: miker@blackburnconsulting.com 2491 Boatman Avenue, West Sacramento, CA 95691 :http:smileyembarrassed::http:smileyembarrassed: www.blackburnconsulting.com:blocked::mailto:brendaf>
    Mike R.
    New Member
    01-07-2013 02:04 PM in reply to: miker
    Hi - Can you explain how you solved this issue in more detail? I'm having the same problem- layers show up as gray in both model and paper view but colors are correct in the properties pane.
    Thanks!
