Alignment types question
Does it matter what Alignment Type I select when making an alignment from objects?
What impact could that have on my Corridor?
It seems that I can control the widening of my Assembly with a Centerline type alignment even though it is more of an Offset or Curb Return alignment type.  Do the different Alignment Types behave differently?  Maybe for some sub-assemblies?
Joe-Bouza
I think it is a book keeping thing
Joe Bouza
jmayo-EE
Nothing will corrupt or have tremendous negative effects on your file by choosing a 'wrong' alignment type. Use common logic and all should be OK. If you need to change and alignment type this can be done right in the alignment's properties dialog.
John Mayo
PE, CFM, CME
alt="EESignature" width="244" height="22">
