• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    Alignment station modification
    176 Views, 8 Replies
    11-21-2012 01:41 PM
    When an alignment needs to have stationing modified, what is the best process for this when a proposed grade line and corridor have been established?  I know the proposed grade line can be edited via edit profile geometry>profile grid view.  But what from I have found each station has to be modified individually, which is cumbersome.  I would hope to be able to modify the proposed grade line by changing only the beginning station and the rest would update, similar to the alignment.
    C3D 2011, (latest updates)
    Win 7 Pro, 64-bit
    16 GB RAM
    Please use plain text.
    Re: Alignment station modification
    11-21-2012 01:56 PM in reply to: rwatson654
    When you say "have stationing modified" are you saying just the station values need to change (say from 0+00 to 10+00), or are you actually making horizontal changes to your alignment.
    Bruce
    11-21-2012 01:59 PM in reply to: bruce.jordan
    Changing the station number, not modifying the layout.  Like you said changing from 0+00 to say 10+00.
    11-21-2012 02:32 PM in reply to: rwatson654
    I think I may have misread your original post.
    Are you looking to "move" your profile, and leave the alignment stationing alone?
    -Bruce
    Valued Mentor
    11-21-2012 03:18 PM in reply to: rwatson654
    Click on the alignment, go to Alignment Properties > Stations tab, and you will see where you can type in a new beginning station for your alignment, and/or you can pick a new place on the alignment for your beginning station location. You will receive warning messages everytime you try this, so just click OK and do what you need to do.
    11-21-2012 04:18 PM in reply to: castled071049
    Those warning messages are there for a reason.
    The OP has design profiles and corridors, I don't thnk the results will be what they want.
    -Bruce
    11-21-2012 04:22 PM in reply to: rwatson654
    rwatson654 -
    If you are just wanting to move alignment stationing from 0+00 to 10+00 for example then take a look using station equations found in the alignment properties.
    -Bruce
    *Expert Elite*
    Joe-Bouza
    11-21-2012 06:16 PM in reply to: rwatson654
    One way is you can create and expression to add to the station labes 1000 and nothing will be altered in the pgl or corridor
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    11-26-2012 05:56 AM in reply to: Joe-Bouza
    didn't think of an expression, good idea. was hoping autodesk would build this in.  seems like i need to modify alignment stations on and so forth on a lot of projects (clients who want specific stationing but don't let you know until 90% completed projects.
