AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Alignment linetype
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For some reasons, my alignments take on a zig-zag linetype (or at least the appearance of that linetype). I can change it to any linetype, and it stays the same. Checked the style, and the linetype and colors are set for Bylayer, and the layer linetype is CENTER. Any ideas? Screen capture attached. Thanks!
Civil 3D 2012
Win 7 Ultimate x64
Intel Core 2 3.2Ghz - 12MB RAM
Nvidia 8500GT Dual DVI
Re: Alignment linetype
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What about the linetype in the alignment style?
Also, did you get any warnings/notices when the drawing opened about replacement shapes/fonts?
You may have to close the drawing and reopen it to review the command history immediately after opening.
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I did check the linetype in the alignment style - set to BYLAYER. Tried changing to Center with no difference. All other objects using the center linetype are fine - only seems to effect alignments. Has also happened in other drawings as well. Will try reloading the linetype from the ACAD.lin file - may be something in my custom linetype file (although this only started happening in the last few days...)
Civil 3D 2012
Win 7 Ultimate x64
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you post a small drawing exhibiting this issue?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I found out the problem was with a custom linetype file I loaded - was trying to get a particular fence line out of that file and just reloaded all the linetypes in that file and apparently the CENTER style in that file was using that batting-type pattern. Reloaded the CENTER linetype from the ACAD.lin file and that solved it. Thanks for the help!
Civil 3D 2012
Win 7 Ultimate x64
