• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Alignment Station & Offset Label Style - Dragged State.
    308 Views, 9 Replies
    12-27-2012 06:54 AM
    My dragged state leader does not display properly.  The attachment runs through my first line of text. Any suggestions out there that may correct this problem? My display is set to "As Composed" I do not want the stacked text setting.
    Thank you.   I have attached a picture that shows the issue I am having.
    Please use plain text.
    Valued Contributor
    Re: Alignment Station & Offset Label Style - Dragged State.
    12-27-2012 07:08 AM in reply to: DEVR3455
    Send an image of what your Layout Settings are set to.
    Jonathan Stewart
    CADvisers
    P.O. Box 7811
    Lancaster, PA 17604
    Ph. 717-468-3111
    Active Member
    12-27-2012 07:41 AM in reply to: CADvisers
    I have attached all the label style settings. When you wrote send the layout settings I was thinkingh you mean the label style setings.
    Valued Contributor
    12-27-2012 08:45 AM in reply to: DEVR3455
    I was meaning how is the text to look without being stacked.   It seems to me that you have the text manally stacked in the contents if you have the dragged state set to AS COMPOSED.  But in doing this it will override the leader attachment location.
    Jonathan Stewart
    CADvisers
    P.O. Box 7811
    Lancaster, PA 17604
    Ph. 717-468-3111
    *Expert Elite*
    12-27-2012 09:04 AM in reply to: DEVR3455
    If the "STA" is to the right of the leader when it's on the right of the leader and if it's how your image depicts it when it's on the left, there's little besides "stacked" you can do besides turn off the leader and add your own leader manually. .
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Active Member
    12-27-2012 09:15 AM in reply to: CADvisers
    Yes I did stack my text manually in the contents field. I did not know using "As Composed" would override the leader settings. Guess I am going to have to live with the display setting set to "Stack".
    Thanks for your help.
    Active Member
    12-27-2012 09:18 AM in reply to: mathewk
    Yes it looks like I am going to have to go with  the Stack text setting. I can live with it and it beats creating leaders manually, too much work I have a large number of Sta & Offset labels.
    Valued Contributor
    12-27-2012 09:20 AM in reply to: DEVR3455
    How is the text looking when setting it to stacked?
    If it's modifying it too much,  Copy the style you have and have the text attachment set to middle right instead of middle left.   So you'll have two styles for either location.
    Jonathan Stewart
    CADvisers
    P.O. Box 7811
    Lancaster, PA 17604
    Ph. 717-468-3111
    Active Member
    12-27-2012 09:55 AM in reply to: CADvisers
    Yes I thought of creating two styles as well. I am keeping my labels left justified, I have enough room in the drawing and I like the uniform and neat look being displayed. But, I am saving the right justified  label in my DWT for future use.
    Thanks again
    Valued Contributor
    12-28-2012 10:52 AM in reply to: DEVR3455
    In the settings file, under Leader Attachment, it is set to "Middle of Top Line"
    Look and see if there as a Left or Right justification to attach it too.
    I haven't done any testting on that but that looks like that could be where you need it to go.  If so, changing it once in the style will change all of them.
    Surveyor Lee
