AutoCAD Civil 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Rad Lazic
Alignment - Geometry Point Label Style - Tick
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
98 Views, 1 Replies
03-17-2004 08:36 PM
I am trying to define this labeling style but the arrow block I'm trying to use is not respecting the "Force inside curve" option that I set
Other elements of the label work like a charm but I think that block objects are missing the "add 180deg" statement somewhere there...
The attached image displays it all.
Is there a workaround? Please advise.
Before I give up and use the circle block.
Rad Lazic
BE (Civ), MIE (Aust), PEng
Autodesk Land Solutions
*Daniel Philbrick
Re: Alignment - Geometry Point Label Style - Tick
Options
- Highlight
- Email to a Friend
03-18-2004 06:21 AM in reply to:
*Rad Lazic
Rad,
The "Tick" component is really intended appy a line, circle or block at the specific station intervals. Other than that, it does not have other specific behavior. In order to create a Geometry Point label style that has the apperance that you have in this post, do the following:
1. Edit the label style via the label style composer, select the layout tab, and create a new block component and give it a name of "Arrow Head".
2. In the block category, select the block name cell and browse to the AeccArwClosedFill block.
3. You now want to "anchor" the block to the line component which is already in the label style. To do this, select the "line" from the list that is in the "Anchor Component" list (in the General category).
4. Lastly, you want the block to be Anchored to the start of the line. Select "Start" from the Anchor Point.
5. You can then set the color and other attributes to your specification.
This should give you an arrowhead, attached to the line, with the behavior you want.
It does work and looks good.
Let me know if you cannot get it to work.
Daniel Philbrick
ISD Civil Development.
"Rad Lazic" wrote in message news:40592761_3@newsprd01...
Rad Lazic
