• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Align section view in viewport
    176 Views, 2 Replies
    12-08-2012 04:23 AM
    When using "Create Multiple Section Views", some of the information is placed outside the viewport.
    How can i get this information inside ?
    Please use plain text.
    BrianHailey
    Re: Align section view in viewport
    12-08-2012 11:34 AM in reply to: karstein
    Add a couple data bands to the profile views (as you are creating the section views) that are invisible but extend out beyond the edge of the view left and right to adjust the limits. When you create just a section view, C3D doesn't recognize the text so it uses the axis as the limits of the view. If your text is adjusted outside of the view, C3D doesn't realize it's there.
    If you have the default template installed, there is a profile band set that is used for this when doing plan and profile sheets. I don't have C3D on this computer but I believe it's called something like, "Plan and Profile Stations and Elevations". The concept for section views is the same.
    New Member
    12-10-2012 04:42 AM in reply to: karstein
    Thank you!
    I will try that.
