• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    SantiagoSoto1974
    After Lofting, Autocad/Civil 3D closes when saving the file.
    109 Views, 5 Replies
    10-17-2012 09:12 AM
    Hello Gents
    The issue here is that I can not save the CAD file with the shapes I need to provide to the client.
    I use the Civil Infrastructure Suite 2013.
    The program makes it possiible to create the Lofting Surface between sections/profiles (from two to eight), but when saving the file, after creating the surfaces, Autocad is forced to close the program suddenly, therefore, no joy on saving the shape  acheived by the program, again and again.
    I hope you can help, it used to work in 2012R.
    Thanks and Kind Regards.
    Santi.
    SYSTEM GENERAL DESCRIPTION
    OS Name    Microsoft Windows 7 Professional
    Version    6.1.7601 Service Pack 1 Build 7601
    Other OS Description     Not Available
    OS Manufacturer    Microsoft CorporatioN
    System Manufacturer    Intel Corporation
    System Model    W2600CR
    System Type    x64-based PC
    Processor    Intel(R) Xeon(R) CPU E5-2687W 0 @ 3.10GHz, 3101 Mhz, 8 Core(s), 16 Logical Processor(s)
    BIOS Version/Date    Intel Corp. SE5C600.86B.01.02.0009.042520121156, 25/04/2012
    SMBIOS Version    2.6
    Windows Directory    C:\Windows
    System Directory    C:\Windows\system32
    Boot Device    \Device\HarddiskVolume1
    Locale    United Kingdom
    Hardware Abstraction Layer    Version = "6.1.7601.17514"
    Time Zone    GMT Daylight Time
    Installed Physical Memory (RAM)    128 GB
    Total Physical Memory    128 GB
    Available Physical Memory    119 GB
    Total Virtual Memory    256 GB
    Available Virtual Memory    246 GB
    Page File Space    128 GB
    Page File    D:\pagefile.sys
    DISPLAY INFORMATION
    Name    NVIDIA Tesla C2075
    PNP Device ID    PCI\VEN_10DE&DEV_1096&SUBSYS_091010DE&REV_A1\4&2823764D&0&0018
    Adapter Type    Not Available, NVIDIA compatible
    Adapter Description    NVIDIA Tesla C2075
    Adapter RAM    Not Available
    Installed Drivers    nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
    Driver Version    8.17.12.9703
    INF File    oem37.inf (Section017 section)
    Color Planes    Not Available
    Color Table Entries    4294967296
    Resolution    2560 x 1600 x 59 hertz
    Bits/Pixel    32
    Memory Address    0xEC000000-0xECFFFFFF
    Memory Address    0xF0000000-0xF7FFFFFF
    Memory Address    0xF8000000-0xF9FFFFFF
    I/O Port    0x0000CF80-0x0000CFFF
    IRQ Channel    IRQ 4294967241
    Driver    c:\windows\system32\drivers\nvlddmkm.sys (9.18.13.697, 12.82 MB (13,443,944 bytes), 10/10/2012 21:22)
    Name    NVIDIA Quadro 6000
    PNP Device ID    PCI\VEN_10DE&DEV_06D8&SUBSYS_076F10DE&REV_A3\4&23A08B03&0&0010
    Adapter Type    Quadro 6000, NVIDIA compatible
    Adapter Description    NVIDIA Quadro 6000
    Adapter RAM    (1,048,576) bytes
    Driver Version    9.18.13.697
    INF File    oem125.inf (Section030 section)
    Color Table Entries    Not Available
    Resolution    Not Available
    Bits/Pixel    Not Available
    Memory Address    0xD0000000-0xD20FFFFF
    Memory Address    0xD8000000-0xE3FFFFFF
    Memory Address    0xE0000000-0xE3FFFFFF
    I/O Port    0x00003000-0x00003FFF
    IRQ Channel    IRQ 4294967278
    I/O Port    0x000003B0-0x000003BB
    I/O Port    0x000003C0-0x000003DF
    Memory Address    0xA0000-0xBFFFF
    Please use plain text.
    AllenJessup
    Re: After Lofting, Autocad/Civil 3D closes when saving the file.
    10-17-2012 10:17 AM in reply to: SantiagoSoto1974
    I'm not on 2013 so don't know anything about this problem. But, as a workaround, could you wblock the lofted surface to preserve it. It's possible that it could then be inserted after the drawing is closed and reopened.
    As I said. I'm not familiar with the problem and have never tried this. I'm just extrapolating from what I know of the program.
    Allen
    AllenJessup
    10-17-2012 10:19 AM in reply to: SantiagoSoto1974
    BTW. That sound serious enough to open a Service Request with Autodesk, if your on Subscription.
    Allen
    Member
    SantiagoSoto1974
    10-17-2012 11:08 AM in reply to: SantiagoSoto1974
    Hello Allen
    Thanks for the comment, but the last thing I would like, is a "workaround".
    I am afraid I can not admit this kind of behaviour by the software, that we all like, and keep in our businnes, in order to produce the best for our clients.
    We need to keep improving this... "thing".
    Thanks again, let me try other routes and I will keep you informed.
    Santi
    AllenJessup
    10-17-2012 11:12 AM in reply to: SantiagoSoto1974
    Hi Santi,
    I certainly wasn't suggesting it as a final solution. But sometimes you have to take the quick choice when a deadline looms. Let us know what Autodesk says.
    Allen
    Member
    SantiagoSoto1974
    10-17-2012 11:23 AM in reply to: SantiagoSoto1974
    I know, I know
    Please do not get me wrong.
    Autodesk is in the know right know, therefore, as soon as I am in the know of the "Doctors Recipe", I will let you know, and may be... they will let you know.
    Again... we need to keep improving, and very fast.
    Thanks a lot for the reply.
    Santi
