• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    Member
    Adobe Export
    154 Views, 4 Replies
    10-17-2012 06:35 PM
    Has anyone had an issue with having Adobe x or XI installed and lost ability to export to pdf?
    Please use plain text.
    *Expert Elite*
    AllenJessup
    Re: Adobe Export
    10-18-2012 05:13 AM in reply to: davidreese
    No. But I always use CutePDF to create the files.
    Allen
    Valued Mentor
    LisaPohlmeyer
    Re: Adobe Export
    10-18-2012 05:22 AM in reply to: davidreese
    No, but we use Autodesk's DWGtoPDF print driver
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    Member
    Re: Adobe Export
    10-18-2012 06:01 AM in reply to: davidreese
    Here is the interesting thing, I added the post after trying this at home off my work network, then on my network via VPN, and it failed both times. Tried it while hard wired to my network at work this morning and there was no problem exporting to PDF within the Autocad system as it comes without external programs. The reason I like this export method is the layering that is created within the PDF so the user of the PDF can turn off and trun on layers created in the export. So now I am a little unsure why it is having an issue one place and not the other. I suspect it is looking for a file or some driver that is referenced on our server but which is hard to access over a VPN connection. Anyway, I will leave it for the IT folks to figure out. Thanks for your responses
    *Expert Elite*
    Re: Adobe Export
    12-04-2012 10:42 AM in reply to: davidreese
    Autodesk's DWGtoPDF print driver includes object layers.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
