AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Adding data to points
- Highlight
- Email to a Friend
- Report Inappropriate Content
Is there a way to have multiple elvations on a single point?
Such as with a top & bottom of curb.
I have tried to add a component to the style, assign the name as the control, and put in the elevation
I want, but you can't have multiple points with the same name.
anyone.................
Re: Adding data to points
- Highlight
- Email to a Friend
If the elevation is a consistant difference, as your example of top & bottom of curb, you could write an expression then add that to the label style for the elevation. In this case I've created the expression of Point Elevation - 0.5 and shown that below my TC: elevation as FL: (gutter).
Williamson Co. Dept. of Infrastructure
Intel i7 3.33Ghz, 16Gb RAM
Nvidia Quadro 2000D
C3D 2012 SP3, C3D 2014
Win 7-64
Please mark this as the solution if it resolves your issue.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
You can add the additional elevation as a UDP and then it can use it in a label style component.
- Highlight
- Email to a Friend
To answer the original question, you cannot have a vertical wall in C3D (otherwise known as a point with equal xy and different z.
You will have to offset your top of curb horizontally a hair. (Scientifically speaking, a hair being a very small amount)
Win 7 Pro SP1 64 bit
Intel i7 3770 @ 3.40 GHz
16 GB RAM
Civil 3D 2014 (IDSP)
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
As Stacy suggests, User Defined Properties are a good way to do this.
see here for some info:
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/G
I also have used expressions for things like curb and gutter, where all you want is a label that takes the point elevation and adds or subtracts a curb height to it.
(running C3D 2012 sp3, Win7 64bit)
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
For situations where I need a top & bottom of curb I created an expression with a consistant elevation difference. I also have times when I have a wall top and then changing ex ground elevations. For these I used the UDP
and both are working great. Thank you for your help
- Highlight
- Email to a Friend
can you explain the stepses to do that. I don't know what do you mean of UDP.
For your advice
Thank you.
to Remember Please Accept as Solution and Kudos Please
