• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Redli1
    Accepted Solution
    Adding Profile Elevation
    221 Views, 15 Replies
    01-21-2013 12:28 PM
    I have a surface profile 1 and a corresponding water level profile 1 of a flood plain. Now I get an updated surface profile 2 and the engineer ask me to ajust the water level according to the difference of surface level 1 and 2.
    How can I add a irregular distance (water depth)  to surface profile 1?
    Please use plain text.
    *Expert Elite*
    Re: Adding Profile Elevation
    01-21-2013 12:30 PM in reply to: Redli1
    Not sure exactly what you're trying to do.  Does copying the surface help?  Then you can raise or lower the copy by the necessary amount and add that surface profile to the profile view.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Redli1
    01-21-2013 12:42 PM in reply to: troma
    At each station the delta (suface profile 1 - surface profile 2) is different. I have to adjust the water level profile according to this delta
    Valued Mentor
    fcernst
    01-21-2013 02:16 PM in reply to: Redli1
    Do you know SAC?
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Redli1
    01-21-2013 02:38 PM in reply to: fcernst
    so far I don not have a corridor. why should a make one?
    Valued Mentor
    fcernst
    01-21-2013 02:45 PM in reply to: Redli1
    I can quickly kick out your required adjusted profie and floodplain delineation all in one shot.
    Ernst Engineering
    Fred Ernst, PE
    Redli1
    01-21-2013 02:58 PM in reply to: fcernst
    I hope somebody else can help me?
    Valued Mentor
    fcernst
    01-21-2013 03:08 PM in reply to: Redli1
    Oh ok if you don't have time to explore that,  you can just post the drawing with the profiles and I can do that for you real quick, no charge.
    Ernst Engineering
    Fred Ernst, PE
    *Expert Elite*
    01-22-2013 05:18 AM in reply to: Redli1
    Is your water level profile from a surface too?
    If you do a volume surface between Surface1 & Surface2, this will give you the difference between them at every station.  You could then paste that volume surface into a regular surface, and do another volume surface between that and the water surface.  This will add the difference between the first two onto the water surface.  But you will have to figure out which one is Base and which one is Comparison in each case.
    Valued Mentor
    fcernst
    01-22-2013 06:34 AM in reply to: Redli1
    So many good options out there...
    Here's another one:
    You can always output the profiles to XML and quickly get the data to crank on in Excel. Then bring it back with XML:
    <Profile name="Main RD">
    <ProfAlign name="Main-FGCL">
    <PVI>0.507625059359 2506.</PVI>
    <PVI>582.340948472239 2523.219164741822</PVI>
    <PVI>1511.652753557886 2507.38066067943</PVI>
    </ProfAlign>
    </Profile>
    Ernst Engineering
    Fred Ernst, PE
