AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Adding Profile Elevation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a surface profile 1 and a corresponding water level profile 1 of a flood plain. Now I get an updated surface profile 2 and the engineer ask me to ajust the water level according to the difference of surface level 1 and 2.
How can I add a irregular distance (water depth) to surface profile 1?
Re: Adding Profile Elevation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not sure exactly what you're trying to do. Does copying the surface help? Then you can raise or lower the copy by the necessary amount and add that surface profile to the profile view.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
At each station the delta (suface profile 1 - surface profile 2) is different. I have to adjust the water level profile according to this delta
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you know SAC?
Fred Ernst, PE
C3D 2013 SP1, C3D 2014
W7x64; i7 8gb; Radeon HD 5700
www.ernstengineering.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
so far I don not have a corridor. why should a make one?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can quickly kick out your required adjusted profie and floodplain delineation all in one shot.
Fred Ernst, PE
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I hope somebody else can help me?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Oh ok if you don't have time to explore that, you can just post the drawing with the profiles and I can do that for you real quick, no charge.
Fred Ernst, PE
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is your water level profile from a surface too?
If you do a volume surface between Surface1 & Surface2, this will give you the difference between them at every station. You could then paste that volume surface into a regular surface, and do another volume surface between that and the water surface. This will add the difference between the first two onto the water surface. But you will have to figure out which one is Base and which one is Comparison in each case.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So many good options out there...
Here's another one:
You can always output the profiles to XML and quickly get the data to crank on in Excel. Then bring it back with XML:
<Profile name="Main RD">
<ProfAlign name="Main-FGCL">
<PVI>0.507625059359 2506.</PVI>
<PVI>582.340948472239 2523.219164741822</PVI>
<PVI>1511.652753557886 2507.38066067943</PVI>
</ProfAlign>
</Profile>
Fred Ernst, PE
