• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Neilw
    Add rebuild Surface to Ribbon and Mouse
    175 Views, 4 Replies
    12-19-2012 10:49 AM
    I would like to add a Rebuild Surface command to my Ribbon Modify Panel. I would also like to have it included in my Right Click menu after a surface is selected. There doesn't appear to be any way to initiate a surface rebuild from the command line and I don't find a command for it in the CUI editor.
    There does seem to be a rebuild command in the API but I am not a programmer. Is this possible without programming?
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Please use plain text.
    Re: Add rebuild Surface to Ribbon and Mouse
    12-19-2012 11:10 AM in reply to: Neilw
    This is how I customized my CUI to get around the issue of not having that functionality built in. I added a button to the quick access toolbar.
    Once in the CUI editor
    1. Make a new command called "REBUILDSURFACE" by clicking the star/asterisk in the command list.
    2. In the new command define the macro as:
    ^C^C_REBUILDSURFACE
    3. Drag the new command to the Civil 3D Quick Access Toolbar
    4. Close CUI and select your surface and then click the new rebuild surface button.
    Hope that helps.
    -Dustin
    Civil 3D 2013 64 bit SP1
    Windows 7 Pro 64
    Intel Xeon 2.93GHz
    24GB RAM
    NVIDIA Quadro FX 580
    explodetheblock.wordpress.com
    Neilw
    12-19-2012 01:16 PM in reply to: dasindog
    That worked nicely. How did you know about the REBUILDSURFACE command? It does not show up when I searched for it in the CUI editor.
    Thanks Dustin
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    12-20-2012 05:17 AM in reply to: Neilw
    Noticed it while flipping through the command autocomplete one day. Now you have me looking into modifying the ribbon. I'll update you if I figure out something worth sharing.
    -Dustin
    Windows 7 Pro 64
    Intel Xeon 2.93GHz
    24GB RAM
    Valued Mentor
    LisaPohlmeyer
    12-20-2012 05:44 AM in reply to: Neilw
    Not to take away from the solution, but when I select a surface, the rebuild surface command is already on the rt-click menu.  I haven't modified my stock CUI at all.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
