• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Add base or sub-base depth to transition lane?
    240 Views, 5 Replies
    04-06-2011 08:25 AM
    Is it possible to add a base depth to the transition lane assembly?   I need to do volumes for my road, (pavement, base) but there is a section with a transition (which only has one depth), so that section is off.
    Please use plain text.
    Product Support
    Jason.Hickey
    Re: Add base or sub-base depth to transition lane?
    04-06-2011 09:20 AM in reply to: rhdins
    The basic assemblies are not meant to be used for design work, although a lot of people do. The correct tool for your task is the LaneOutsideSuper - this has 4 levels of materials and can target an alignment for transition purposes.
    Jason Hickey
    Premium Services Specialist
    Autodesk, Inc.
    02-13-2013 12:24 PM in reply to: rhdins
    Jason
    I think your comment did not quite answer this question.  I think goal here was to transition pavement thickness1 @station1 to thickness2@station2...  Transitioning from width1 to width2 is easy, but material depth cannot be changed in the same manner...
    02-13-2013 03:48 PM in reply to: rhdins
    I have not come across a stock subassembly that allows the variable depth, but there is a solution that could automate this for you.  It involves creating a "depth" profile, which would represent the depth of your pavement material over the station range that you need.  Add this profile under the same parent alignment as your road design. (This will be needed in your corridor as a slope/elevation target).  From there you will need to add a generic link (suggest the LinkSlope&VerticalDeflection) to your assembly baseline marker.  This link is used just to incorporate the depth measurement into your assembly and will target the depth profile within your corridor.  It should be added to your overall assembly as part of the same group as the pavement subassembly.  Also, you will need to make sure that the generic link subassembly is "above" the pave subassembly in the Construction order. (See Image1).  Next, in your Assembly properties you'll need to set a Paramter Reference for pavement material that you are using to use the End Elevation of the generic link.  (See Image2).  And finally, you'll need to set the region targets in your corridor so that the generic link targets the depth profile.
    It seems like quite a few steps, but it will accomplish the job.  One drawback to this is when you view your sections, or create section views.  If you use the Automatic elevation range for section views, it will elongate your views.  The quick and easy fix to that is to use a "User Defined" height.
    Maybe there is an easier way, but this will work if nothing else comes your way.
    02-13-2013 03:55 PM in reply to: rhdins
    Thank you
    I thought about this, but I find it to be to convoluted... especially with vertical curves thrown in the loop! But thanks anyways
    *Expert Elite*
    sboon
    02-13-2013 11:04 PM in reply to: mariepl
    Matt Kolberg posted another version of this solution over at Civil4D.com back in May 2012.  The big adantage in this case is that the transition is in the depth/thickness of the material.  The vertical curves in the design profile are not an issue using this method.
