AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Add Station and Offset to a point
- Highlight
- Email to a Friend
I currently have a drawing with a road alignment and stationing. Is there a way to automatically station and offset a point that is not on the alignment line?
For instance, our alignment line is the centerline of the road. I need a station and offset of the new right of way line points at different places in the drawing. I want to use the alignment stationing to have it automatically create the station and offset at the point I choose.
Thanks.
Caryn
Re: Add Station and Offset to a point
- Highlight
- Email to a Friend
I don't understand very well. Do you have a polyline next to the aligment as rigth of way? and do you want to put the station and offset for each polyline point?. Is it correct?
- Highlight
- Email to a Friend
Try Create Points > Alignments > Station/Offset; you'll then need to choose thealignment from which you're offsetting, then enter the station along the alignment and the offset distance.
HTH.
- Highlight
- Email to a Friend
That option will create cogo points. Is that what you want?
I thought you just wanted a simple label of the station & offset. If so, go to Annotate > Add Labels >
Feature: Alignment
Label type: Station Offset - Fixed Point
These labels display the station & offset from the alignment and will dynamically update if the alignment is edited or the label is moved.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
I found the answer.
Select the alignment - in the Alignment Tab select Add Labels - Station and offset.
Thanks.
