• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Add Station and Offset to a point
    219 Views, 4 Replies
    01-07-2013 02:56 PM
    I currently have a drawing with a road alignment and stationing.  Is there a way to automatically station and offset a point that is not on the alignment line?
    For instance, our alignment line is the centerline of the road.  I need a station and offset of the new right of way line points at different places in the drawing.  I want to use the alignment stationing to have it automatically create the station and offset at the point I choose.
    Thanks.
    Caryn
    Please use plain text.
    arcallupe
    Re: Add Station and Offset to a point
    01-07-2013 04:04 PM in reply to: mnyrac
    I don't understand very well. Do you have a polyline next to the aligment as rigth of way? and do you want to put the station and offset for each polyline point?. Is it correct?
    Valued Contributor
    01-07-2013 04:17 PM in reply to: mnyrac
    Try Create Points > Alignments > Station/Offset; you'll then need to choose thealignment from which you're offsetting, then enter the station along the alignment and the offset distance.
    HTH.
    *Expert Elite*
    01-08-2013 05:46 AM in reply to: seattlesurvey
    That option will create cogo points.  Is that what you want?
    I thought you just wanted a simple label of the station & offset.  If so, go to Annotate > Add Labels >
    Feature: Alignment
    Label type: Station Offset - Fixed Point
    These labels display the station & offset from the alignment and will dynamically update if the alignment is edited or the label is moved.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Active Contributor
    01-08-2013 06:22 AM in reply to: troma
    I found the answer.
    Select the alignment - in the Alignment Tab select Add Labels - Station and offset.
    Thanks.
