• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    ADD A TURN OUT ALONG A BIKE PATH CORRIDOR
    197 Views, 4 Replies
    10-29-2012 12:29 PM
    I need to add a turnout (not intersection) along a bike path at a given station (see pdf attachment)
    if I draw a turnout with nice arcs and lines, is there a way to add it to the corridor with extended
    cross slope from the assembly at that point?
    John Wilson
    Please use plain text.
    Active Contributor
    bpoleuca
    Re: ADD A TURN OUT ALONG A BIKE PATH CORRIDOR
    10-29-2012 12:55 PM in reply to: johnwilson0805
    yes, it's possible.
    You have to use a BasicLaneTransition.
    Please use help for better explainance.
    Good luck.
    Active Contributor
    10-29-2012 04:48 PM in reply to: bpoleuca
    Thank you very much. It helped to research edit target to a polyline layout
    John
    *Expert Elite*
    Neilw
    10-29-2012 11:45 PM in reply to: johnwilson0805
    While polylines can be used as targets they are static entities, so they don't move if your alignment changes. A better solution is to use offset alignments with widenings. Then you can move the widening along the baseline or edit it parametrically. You want a solution that is dynamic to changes to the design.
    Also for a widening you should consider using an offset in your assembly so that your template will be perpendicular to the edge of pavement through the widening.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Active Contributor
    10-31-2012 06:47 AM in reply to: Neilw
    Thanks Neil
    I'll look imto that
    John
