• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    2D area of a cross section
    297 Views, 9 Replies
    02-15-2013 04:28 PM
    I have a cross section view with a canal section and a flat water surface section.
    Is there a way for C3D to calculate the 2D area of the canal section that is under the water elevation?
    Mike Porter
    www.ppeng.com
    Civil3D 2013
    Win 7 Professional - 64-bit
    HP Z400
    Xeon W3550 @ 3.07Ghz
    8GB of RAM
    Nvidia Quadro FX 3800
    Please use plain text.
    Distinguished Mentor
    Jay_B
    Re: 2D area of a cross section
    02-15-2013 06:10 PM in reply to: mikepo
    Are you looking for 2d area of the cross sections per section view in square ft?
    Or a surface area of all canal bottom that is submerged that takes into account the variation (3d) in side slopes &; bottom?
    Could you post a sketch showing what is needed?
    Jay
    C3D 2012 SP3
    Win 7 Professional 64 Bit
    *Expert Elite*
    02-15-2013 11:15 PM in reply to: mikepo
    You'll need to use the compute materials tool which is used to calculate volumes.  Then output new section views and include the volume table for each view.  This volume table will list the 2D area between the 2 surfaces.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    02-19-2013 09:12 AM in reply to: mikepo
    Here's a sketch of what I'm trying to do.
    Mike Porter
    www.ppeng.com
    Civil3D 2013
    HP Z400
    8GB of RAM
    *Expert Elite*
    02-19-2013 09:16 AM in reply to: mikepo
    See my previous reply.
    Matt Kolberg
    02-19-2013 09:42 AM in reply to: mathewk
    I got it to work on practice surfaces. Now we'll see if I can do it for the real world. :smileyhappy:
    Thanks.
    Mike Porter
    www.ppeng.com
    Civil3D 2013
    HP Z400
    8GB of RAM
    Jay_B
    02-19-2013 09:44 AM in reply to: mikepo
    Mike,
    So it appears your not interested in the "average end area" in SF but rather LF of submerged bottom beginning at water level on left and terminating at water level on right?
    Jay
    C3D 2012 SP3
    02-19-2013 10:18 AM in reply to: Jay_B
    That is correct.
    I apologize, I didnt' catch your question in the original post.
    Thanks.
    Mike Porter
    www.ppeng.com
    Civil3D 2013
    HP Z400
    8GB of RAM
    Valued Mentor
    02-19-2013 02:23 PM in reply to: mikepo
    you could create the cross section view showing the existing ground and the water surface, explode the sections twice, then trim the ground to the water surface to find its wetted perimeter (see attached video, rename the file to remove the ".txt" portion from filename). make sure your section views are created with no vertical exaggeration. not the most elegant method, especially if you have to compute wetted perimeters for multiple cross sections, but that's the best i can think of at the moment.
    P.S: ingore the fact that the water surface elevation has ups and downs in the section view of the video, it represents FG for my project, but the idea is the same.
    Civil 3D 2013 SP1, Win 7-64 bit
    12GB RAM
    Jay_B
    02-19-2013 06:02 PM in reply to: mikepo
    Looks like that will work but you may want to "Export to AutoCad DWG" prior to all the trimming etc.,
    which will also do the exploding for you. The resulting file would just be a working drawing for this exercise.
    The integrity of your data wont be compromised in your source drawings either.
    Jay
    C3D 2012 SP3
