AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
2013 bug - corridor feature lines
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a road corridor with feature lines connecting the road edges (cyan), ditchline (dark green), daylight_cut (yellow), daylight_fill (green) and daylight (white). At certain random locations along this corridor I am getting feature lines which span from one station to another, ignoring all of the corridor sections in between. The image below shows a daylight_fill line spanning over 60m, even though there is a daylight line through this region.
In this area a ditch line and a daylight_cut start at 4+110, skip over the next cut section at 4+120 and jump over a hundred meters to the next piece of ditch at 4+280
This corridor builds clean - no error messages reported. Is anybody else seeing this behaviour?
Re: 2013 bug - corridor feature lines
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you post the dwg? or a sample dwg?
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not on a public board Dana, but PM me and I'll arrange to get it to you somehow.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you make it fail in a tutorial or sample dwg?
You can email me the dwg if you like and I can see if I can get it looked at. First dot last at youknowwhere.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the Feature Lines tab of corridor properties...Does Branching Inward or Outward make a difference?
Brent
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Nope.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I know that you have probably checked this... but just looking at your screen capture, I have to ask.
Is there a corridor surface in your dwg with the border only display on?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Steve,
To answer your previous question...Yes, I saw this a few times...branching outward solved it for me a couple times.
Good luck.
Brent
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No surface Dana. The green lines are Daylight_Fill feature lines, the yellow ones are Daylight_Cut, and the white ones are Daylight codes. The darker green ones parallel to the Daylight_Cut are the Ditch codes.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Steve,
Was the assembly built in 2013?...have had problems mixing subassemblies from different versions of software.
Brent
