• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    sboon
    2013 bug - corridor feature lines
    824 Views, 14 Replies
    04-17-2012 11:00 AM
    I have a road corridor with feature lines connecting the road edges (cyan), ditchline (dark green), daylight_cut (yellow), daylight_fill (green) and daylight (white).  At certain random locations along this corridor I am getting feature lines which span from one station to another, ignoring all of the corridor sections in between.  The image below shows a daylight_fill line spanning over 60m, even though there is a daylight line through this region.
    In this area a ditch line and a daylight_cut start at 4+110, skip over the next cut section at 4+120 and jump over a hundred meters to the next piece of ditch at 4+280
    This corridor builds clean - no error messages reported.  Is anybody else seeing this behaviour?
    Please use plain text.
    Employee
    Re: 2013 bug - corridor feature lines
    04-17-2012 01:00 PM in reply to: sboon
    Can you post the dwg? or a sample dwg?
    Dana Probert, P.E.
    Technical Marketing Manager, Civil Engineering
    Blog: BIM on the Rocks
    Learn More About BIM for Infrastructure
    *Expert Elite*
    sboon
    04-17-2012 01:23 PM in reply to: dana.probert
    Not on a public board Dana, but PM me and I'll arrange to get it to you somehow.
    Employee
    04-19-2012 11:17 AM in reply to: sboon
    Can you make it fail in a tutorial or sample dwg?
    You can email me the dwg if you like and I can see if I can get it looked at. First dot last at youknowwhere.com
    Dana Probert, P.E.
    Distinguished Contributor
    04-19-2012 11:43 AM in reply to: sboon
    In the Feature Lines tab of corridor properties...Does Branching Inward or Outward make a difference?
    Brent
    *Expert Elite*
    sboon
    04-19-2012 11:55 AM in reply to: bigblittlerent
    Nope.
    Employee
    04-19-2012 11:57 AM in reply to: sboon
    I know that you have probably checked this... but just looking at your screen capture, I have to ask.
    Is there a corridor surface in your dwg with the border only display on?
    Dana Probert, P.E.
    Steve,
    To answer your previous question...Yes, I saw this a few times...branching outward solved it for me a couple times.
    Good luck.
    Brent
    *Expert Elite*
    sboon
    04-19-2012 12:08 PM in reply to: dana.probert
    No surface Dana.  The green lines are Daylight_Fill feature lines, the yellow ones are Daylight_Cut, and the white ones are Daylight codes.  The darker green ones parallel to the Daylight_Cut  are the Ditch codes.
    04-19-2012 12:16 PM in reply to: sboon
    Steve,
    Was the assembly built in 2013?...have had problems mixing subassemblies from different versions of software.
    Brent
