• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    gccdaemon
    Accepted Solution
    2013 Scale List in registry
    219 Views, 5 Replies
    01-28-2013 01:38 PM
    Having trouble finding the correct place to put the FEET, INCHES, METRIC, custom scales in the registry. Can anyone help? I'm not sure if its any of the following or is it somewhere else now?
    [HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B000:409\
    [HKEY_LOCAL_MACHINE\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\AEC\7.0\AecBase70\Scales\
    [HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B000:409\
    [HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\AEC\7.0\AecBase70\Scales\
    Andrew Ingram
    Civil 3D x64 2012
    Win 7 x64 Ultimate
    I7 3820 (3.6ghz quad core with HT)
    32gig RAM (Corsair XMS3 4x8g)
    Intel x z79 mobo (BOXDX79TO 2011 socket)
    Radeon HD 7850 2gb GDDR5
    Please use plain text.
    Valued Mentor
    gccdaemon
    Re: 2013 Scale List in registry
    01-28-2013 03:16 PM in reply to: gccdaemon
    Bump
    Andrew Ingram
    Civil 3D x64 2012
    Win 7 x64 Ultimate
    Valued Mentor
    gccdaemon
    01-29-2013 12:31 PM in reply to: gccdaemon
    bump
    Andrew Ingram
    Civil 3D x64 2012
    Win 7 x64 Ultimate
    Active Contributor
    01-30-2013 09:27 AM in reply to: gccdaemon
    [HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\Scale List]
    This is the location I have. The attached file adds the scales that I need. I found this somewhereon the forum a while ago so I don't know who to give the credit to.
    Edit: Autodesk won't let me post the file so I have renamed the extension. Save the .doc to your computer and rename it to .reg then you should be able to run it.
    Dell Inspiron 546
    8 GB Ram
    Win 7 64-bit SP1
    Civil 3D 2013 SP1
    Valued Mentor
    gccdaemon
    01-30-2013 01:26 PM in reply to: aluster
    This location was correct for 2012, but it's not working for 2013. I think they changed the override function. When i reset the scale list it puts the default scales in rather than adding the overridden values sent in your file. Hopefully someone from Autodesk chimes in on this, because I have standards i have to deploy.
    Andrew Ingram
    Civil 3D x64 2012
    Win 7 x64 Ultimate
    Valued Mentor
    gccdaemon
    01-30-2013 02:39 PM in reply to: gccdaemon
    Figgured it out!!!! On the very first scale, (the "0" grouping) you have to set the scale type to 3. If you don't it doesn't import the custom scale list. YAY ME!
    Andrew Ingram
    Civil 3D x64 2012
    Win 7 x64 Ultimate
