• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    fcernst
    Accepted Solution
    2013 - General Segment Grade Text Component Not Updating
    157 Views, 4 Replies
    10-29-2012 03:12 PM
    I extracted a dynamic feature line from the gutter flowline of my Corridor. I labeled Multiple Segments for the feature line with a grade and vertex style that uses the  "General Segment Grade" text component.
    I am overiding lane cross slopes in the Section Editior and the segment grade labels for the extracted feature line do not update after I Update Corridor in the Section Editior.
    If I raise/lower the CL profile of the corridor, the label updates. Just not reacting to these Corridor edits.
    Peculiar behavior: The label will update to reflect the Corridor update if I Isolate it.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Please use plain text.
    *Expert Elite*
    Re: 2013 - General Segment Grade Text Component Not Updating
    10-29-2012 04:40 PM in reply to: fcernst
    Fred, just fyi, this works correctly in 2013.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Valued Mentor
    fcernst
    10-29-2012 04:42 PM in reply to: tcorey
    It's not working for me in 2013. It's behaving as I describe.
    Ernst Engineering
    Fred Ernst, PE
    Valued Mentor
    fcernst
    10-30-2012 12:46 PM in reply to: tcorey
    Hi Tim,
    I've isolated this to the Update Corridor command within the Section Editor. The Update Corridor command is rebuilding the corridor, updating the surface, updating the Section View, etc., like it should, however the feature line labeling is not updating on this extracted dynamic feature line.
    If I then select the Corridor and Rebuild it from the command on the Corridor tab, the labels update.
    Ernst Engineering
    Fred Ernst, PE
    *Expert Elite*
    10-30-2012 02:22 PM in reply to: fcernst
    Thanks for the follow-up. That's good to know. I'll file that in my (short-term?) memory.
    Tim Corey, Owner
    Redding, CA
