• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    2012 Transportation Extension
    380 Views, 7 Replies
    10-25-2011 07:26 AM
    I am trying to install the 2012 Transportation Extension and when I go to use it I get an error that states
    "Execute File is not exist: C:\ProgramData\Autodesk\C3D 2012\enu\Data\Reports\net\C3DReportTE.dll, please reinstall program"
    I have uninstalled 2012 Civil3D and reinstalled but still cannot get it to work.  It works just fin in 2011.
    Colton
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: 2012 Transportation Extension
    10-25-2011 08:24 AM in reply to: cjkiefer02
    It seems that the file C3DReportTE.dll does not exist in the directory C:\ProgramData\Autodesk\C3D 2012\enu\Data\Reports\net\
    See if you can make a copy of C3DReport.DLL (same directory) and rename that copy to C3DReportTE.dll and then restart Civil 3D. See if the message will go away.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Please click on "Accept as Solution" if post helped you resolve the issue.
    10-25-2011 08:37 AM in reply to: AlmasSuljevic
    It dies work that way but the original report from  C3DReport.DLL is different than the report from C3DReportTE.DLL.
    10-25-2011 08:38 AM in reply to: cjkiefer02
    Here is a screen shot of the 2011 TE box and the 2012 standard report box.
    Product Support
    AlmasSuljevic
    10-25-2011 09:09 AM in reply to: cjkiefer02
    I see the difference. My suggestion was in line that the C3DReportTE.dll was missing and renaming other DLL would allow it to run. Can you copy the 2011 version of the transporation extension C3DReportTE.dll to 2012 directory? That should work too.
    Almas Suljevic
    10-25-2011 09:16 AM in reply to: AlmasSuljevic
    I tried that also.  It is pulling from another file that I cannot seam to find.
    Product Support
    AlmasSuljevic
    12-05-2011 01:02 PM in reply to: cjkiefer02
    I reported this issue to the development and hope to see the new version posted in the near future.
    Almas Suljevic
    Active Contributor
    02-11-2013 08:46 AM in reply to: AlmasSuljevic
    Any resolution to this?
