• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    ACADuser
    2012 Subassembly Reference PDF
    163 Views, 5 Replies
    11-29-2012 10:47 AM
    Does anyone know if the Subassembly Reference (2012 version) is available for download?
    All I seem to be able to find is the online html version.  I need something that can be printed, the online html version is a PIA to work with.
    Thank You,
    ACADuser
    Dell Precision T5500 Workstation
    Windows XP Professional SP3
    Dual Quad Core Intel Xeon Processors E5540 2.53GHz,8M L3,5.8GT/s,turbo
    4GB, DDR3 Memory, 1066MHz, ECC (4 DIMMS)
    1.5GB NVIDIA Quadro FX 4800, DUAL MON, 2DP & 1DVI
    160GB, 3.0Gb/s, 16MB Data Burst Cache,SATA2,10K RPM Hard Drive
    16XDVD AND 16XDVD+/-RW
    Please use plain text.
    philip.s
    Re: 2012 Subassembly Reference PDF
    11-29-2012 12:20 PM in reply to: ACADuser
    Hi Brian,
    Is this what you're looking for by chance?
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    ACADuser
    11-29-2012 01:47 PM in reply to: philip.s
    Phillip,
    Thanks for the response.  Unfortunately the link you provided is not what I am looking for.
    The documentation provided for older releases includes a PDF of the Subassembly Reference.  I can't seem to find a PDF or other printable version of this document for the 2012 version.
    The 2012 version is here (html): http://docs.autodesk.com/CIV3D/2012/ENU/filesCSH/GUID-B35ED378-3D86-4287-83B0-552DB29A0BF-0.htm
    The 2011 version is here (PDF):  http://images.autodesk.com/adsk/files/c3dstocksubassemblyhelp.pdf
    ACADuser
    Product Support
    AlmasSuljevic
    12-03-2012 07:04 AM in reply to: ACADuser
    I don't think the PDF version of the Subassembly Reference is available for 2012 and 2013 version. It is all HTML now.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Please click on "Accept as Solution" if post helped you resolve the issue.
    ACADuser
    12-04-2012 08:19 AM in reply to: AlmasSuljevic
    Almas,
    I was afraid that would be the answer.  Is there some possible way to compile the contents of the html into a single file for printing?
    Thank You.
    ACADuser
    Product Support
    AlmasSuljevic
    12-04-2012 09:11 AM in reply to: ACADuser
    You may want to see this post. At the bottom there is a procedure that one user provided to compile the HTMLs into one document converted to PDF. http://208.74.205.69/t5/AutoCAD-Civil-3D-Wishes/I-wish-we-had-PDF-s-back/td-p/3013556/page/2
    Good luck!
    Almas Suljevic
